Component: Panel Console Viewer (Runtime Tools)
| Author | Matrix Ltd |
| Version | 1.1 |
| Category | Runtime Tools |
Panel Console Viewer component
An easy way to display the data from a console on the panel. Links to a component that generates console data.
| NextRow | |
| Move to the next row in the file | |
| PWMDisable | |
| Disable a PWM output | |
| Channel | |
| Range: 0-1 | |
| I2CStart | |
| Put the I2C Module into Start mode | |
| Channel | |
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| Channel | |
| DataOut | |
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Channel | |
| [[File:]] - | Last |
| I2CStop | |
| Put the I2C Module into Stop mode | |
| Channel | |
| ServoDisable | |
| Disable a Servo output | |
| Channel | |
| Range: 0-5 | |
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
| ServoEnable | |
| Enable a Servo output | |
| Channel | |
| Range: 0-5 | |
| ADCSample10 | |
| Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023 | |
| ADCChannel | |
| Range: 0-5 | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-17 | |
| [[File:]] - | State |
| Range: 0-1 | |
| ServoSetPosition8 | |
| Sets the position as an 8-bit value | |
| Channel | |
| Range: 0-1 | |
| Position | |
| Range: 0-255 | |
| UARTReceive | |
| Channel | |
| SPIInitialise | |
| Channel | |
| WIFIGetIP | |
| Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI, Use the WIFIIsConnected first to check the WIFI is active. | |
| I2CSend | |
| Channel | |
| DataOut | |
| [[File:]] - | Return |
| UARTSend | |
| Channel | |
| Data | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Prescaler | |
| PWMSetDuty8 | |
| Sets the duty for the PWM output | |
| Channel | |
| Range: 0-1 | |
| Duty | |
| Range: 0-255 | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-1 | |
| Properties | |
| Connect To | |
| Width | |
| Width of the console ripper component. | |
| Number of lines | |
| Clear Old Data | |
| Removes old data from the console viewer when starting simulation if active. | |
| Connections | |
| Simulations | |
