Component: Console Writer (Indicators)
Revision as of 20:42, 16 November 2021 by Wiki bot (talk | contribs)
Category Indicators
Console Writer component
A simple component to aid in creating and wiriting data to a console tab. Allows text to be coloured and automatically appended with a timestamp.
Clear
Clears the contents of the console tab.
CountLines
Counts the number of lines in the console.
- ULONG Return
AddString
Adds text string to the console window.
- STRING Data
SetTextLine
Sets the string data from a specific line in the console.
[[File:]] - Line
Line number, -1 for the last line.
- STRING Data
SetColour
Allows for full RGB colour selection
- BYTE R
Colour channel, Range: 0-255
- BYTE G
- BYTE B
SetColourIdx
Sets the text colour from the properties selection of colours.
- BYTE Index
Range: 0-3
GetTextLine
Gets the string data from a specific line in the console.
[[File:]] - Line
- STRING Return
PWMDisable
Disable a PWM output
- BYTE Channel
Range: 0-1
I2CStart
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
I2CReceive
- BYTE Channel
[[File:]] - Last
I2CStop
- BYTE Channel
WIFISetSSID
Assign the SSID and password for the network you wish to connect the board to. Stores the parameters into ROM for later USB free setup.
- STRING SSID
Name of the network you wish to connect to
- STRING Password
ServoDisable
Disable a Servo output
- BYTE Channel
Range: 0-5
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
ServoEnable
Enable a Servo output
- BYTE Channel
Range: 0-5
ADCSample10
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023
- BYTE ADCChannel
Range: 0-5
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
I2CTransInit
- BYTE Channel
- BYTE DeviceAddress
7-bit Device Address
- BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
IOSetOutputPin
- BYTE Pin
Range: 0-17
[[File:]] - State
Range: 0-1
ServoSetPosition8
Sets the position as an 8-bit value
- BYTE Channel
Range: 0-1
- BYTE Position
Range: 0-255
UARTReceive
- BYTE Channel
SPIInitialise
- BYTE Channel
WIFIGetIP
Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI, Use the WIFIIsConnected first to check the WIFI is active.
- STRING Return
I2CSend
- BYTE Channel
- BYTE DataOut
[[File:]] - Return
UARTSend
- BYTE Channel
- BYTE Data
PWMSetPrescaler
- BYTE Prescaler
PWMSetDuty8
- BYTE Channel
Range: 0-1
- BYTE Duty
Range: 0-255
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-1
Console Name
Textual name of the console shown as the tab name at the top of the console window.
Colour 0
Used to define a colour channel referenced by the SetColourIdx component macro call.
Colour 1
Colour 2
Colour 3
New Line After Data
Automatically append a newline character after any data has been written to the console using the AddString component macro.
Clear On Sim Start
Automatically clear the console tab when the simulation is started.
Add Timestamp
Automatically adds a timestamp to the console after a newline character has been received.
Date Format
Specifies the format of the date string. No - "DD/MM/YY" Yes - "MM/DD/YY"
Time Separator
Characters that are used in between the time digits
Date Separator
Characters that are used in between the date digits
TimeStamp Separator
Characters that are used between the time and date strings when returning a full time stamp.
Override Colour
Overrides the current selected colour when writing the timestamp.
Timestamp Colour
Defines the colour of the time stamp text
Simulations
