Component: SRF (WirelessThings) (SRF) (Wireless)
| Author | MatrixTSL |
| Category | Wireless |
SRF (WirelessThings) component
The SRF is designed for wireless transmission and reception of serial data in an easy to use surface mounted module. It has an on-board balun and chip antenna, which can be detached for applications where an external antenna is required.
| SendString | |
| Send a string of data using the SRF Module | |
| Data | |
| Wake | |
| Wake the SRF module. Includes a 10ms delay to allow radio to wake. | |
| SendChar | |
| [[File:]] - | Char |
| Sleep | |
| Sets the SRF module to sleep mode. (Includes a 10mS delay to allow any data to finish sending) | |
| SRFInitialise | |
| Initialise the SRF Module. Activate device through 'enable' pin, and wake device to ensure it is not sleeping. | |
| ReceiveString | |
| Timeout | |
| NumBytes | |
| ReceiveChar | |
| Timeout | |
| [[File:]] - | Return |
| I2CStop | |
| Put the I2C Module into Stop mode | |
| Channel | |
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
| PWMSetDuty | |
| Sets the duty for the PWM output | |
| Channel | |
| Range: 0-5 | |
| Duty | |
| ADCSample10 | |
| Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023 | |
| ADCChannel | |
| Range: 0-12 | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-29 | |
| [[File:]] - | State |
| Range: 0-1 | |
| UARTReceive | |
| Channel | |
| SPIInitialise | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| UARTSend | |
| Channel | |
| Data | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Prescaler | |
| Period | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-1 | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-29 | |
| Range: 0-1 | |
| UARTReceive | |
| Channel | |
| OneWireScanBus | |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
| Channel | |
| SPIInitialise | |
| Channel | |
| OneWireReceiveByte | |
| Receives a byte from the one wire bus a bit at a time | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| UARTSend | |
| Channel | |
| Data | |
| OneWireGetDeviceCount | |
| Returns the number of devices found by the last ScanBus operation. | |
| Channel | |
| PWMSetPrescaler | |
| Channel | |
| Range: 0 - 11 | |
| Prescaler | |
| Period | |
| PWMEnable | |
| Channel | |
| Range: 0-11 | |
