Component: Barometer (MS5637) (Environmental)
Revision as of 20:47, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Environmental
Barometer component
A small PCB surface mount barometric pressure sensor with a I2C bus interface. Pressure range 0 to 30 Bar. Temperature range -20 to +85 °C.
ReadPressureFloat
Reads the pressure as a floating point value in Bars. Resultion sets the return bit value and conversion time. Calls the ReadPressureRaw function and then converts to a meaningful value.
- BYTE Resolution
Range 0-5
[[File:]] - Return
Reset
Resets the device
ReadTemperatureFloat
- BYTE Resolution
Range 0-5
[[File:]] - Return
ReadPressureRaw
Reads the pressure as a digital 32-bit value. Resultion sets the return bit value and conversion time. 0=0.11mBar / 1=0.062mBar / 2=0.039mBar 3=0.028mBar / 4=0.021mBar / 5=0.016mBar
- BYTE Resolution
Range 0-5
- ULONG Return
ReadTemperatureRaw
Reads the temperature as a digital 32-bit value. Resultion sets the return bit value and conversion time. 0=0.012°C / 1=0.009°C / 2=0.006°C 3=0.004°C / 4=0.003°C / 5=0.002°C
- BYTE Resolution
Range 0-5
[[File:]] - Return
ReadPROM
Reads a single 16-bit value from the PROM calibration data.
- BYTE Address
Range 0-6
Stes up the I2C bus and initialises the termperature sensor ready for use.
ReadRegister
Reads a byte from a register
- BYTE Address
WriteRegister
Writes a byte to a register
- BYTE Address
- BYTE Data
Starts up the I2C ready to communicate with the sensor. Sets the selected rates and operational mode. Returns 1 if the sensor has been found and initialised.
[[File:]] - Return
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Injector
Simulations
Simulate Comms
