Component: GLCD (KS0108) (Graphical Monochrome)
Revision as of 21:02, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.4 |- | width="20%" style="color:gray...")
Version 1.4
Category Graphical Monochrome
GLCD (KS0108) component
Graphical display component designed to work with the KS0108 type monochrome displays. Also compatible with the newer S6A0107 controller IC displays.
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
[[File:]] - Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png BPlot
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE Pixel_Colour
0=White, 1=Black
Fc9-comp-macro.png DrawCircle
0=White, 1=Black
Fc9-comp-macro.png Initialise
Fc9-type-16-icon.png Controller Count
Speicifies the number of controller IC's built into the display and therefore the number of available chip select pins
Fc9-type-16-icon.png Display Method
Fc9-type-21-icon.png Enable Delay
Time in micro seconds to wait before and after toggling the enable pin.
Fc9-type-5-icon.png CS1
Chip select to address the first controller IC
Fc9-type-5-icon.png CS2
Chip select to address the second controller IC
Fc9-type-5-icon.png RS
Data / Instruction register select pin.
Fc9-type-5-icon.png RW
Read / write select pin
Fc9-type-5-icon.png Enable
Data enable to clock a command or data in or out of the device
Fc9-type-5-icon.png Data0
Data Pin 0
Fc9-type-5-icon.png Data1
Data Pin 1
Fc9-type-5-icon.png Data2
Data Pin 2
Fc9-type-5-icon.png Data3
Data Pin 3
Fc9-type-5-icon.png Data4
Data Pin 4
Fc9-type-5-icon.png Data5
Data Pin 5
Fc9-type-5-icon.png Data6
Data Pin 6
Fc9-type-5-icon.png Data7
Data Pin 7
Fc9-type-5-icon.png Reset
Display reset pin
Fc9-conn-icon.png Simulations
