Author
Matrix Ltd
Version
1.0
Category
Third Party
FTDI (FTD2XX) component
Simulation only interface to allow communications with a FTDI USB 232 IC connected to the system. For more details refer to the D2XX_Programmers_Guide from FTDI.
FT_GetStatus
Gets the device status including number of characters in the receive queue, number of characters in the transmit queue, and the current event status.
[[File:]] -
Handle
Handle of the device.
[[File:]] -
RxQueueLength
Pointer to a variable of type DWORD which receives the number of characters in the receive queue.
[[File:]] -
TxQueueLength
Pointer to a variable of type DWORD which receives the number of characters in the transmit queue.
[[File:]] -
EventStatus
Pointer to a variable of type DWORD which receives the current state of the event status.
- BYTE
FT_ClrRts
This function clears the Request To Send (RTS) control signal.
[[File:]] -
Handle
FT_Write
Write data to the device.
[[File:]] -
Handle
- BYTE
Buffer
Pointer to the buffer that contains the data to be written to the device.
- ULONG
Bytes
Number of bytes to write to the device.
- ULONG
Count
Pointer to a variable of type DWORD which receives the number of bytes written to the device.
- BYTE
FT_Read
Read data from the device.
[[File:]] -
Handle
- BYTE
Buffer
Pointer to the buffer that receives the data from the device.
- ULONG
Bytes
Number of bytes to be read from the device.
- ULONG
Count
Pointer to a variable of type DWORD which receives the number of bytes read from the device.
- BYTE
FT_SetFlowControl
This function sets the flow control for the device.
[[File:]] -
Handle
- UINT
FlowControl
Flow setting 0=None, 0x0100=RTS/CTS, 0x0200=DTR/DSR, 0x0400=XON/XOFF
- BYTE
Xon
Character used to signal Xon. Only used if flow control is Xon/Xoff
- BYTE
Xoff
Character used to signal Xoff. Only used if flow control is Xon/Xoff
- BYTE
FT_GetModemStatus
Gets the modem status and line status from the device.
[[File:]] -
Handle
[[File:]] -
ModemStatus
Pointer to a variable of type DWORD which receives the modem status and line status from the device.
- BYTE
FT_SetBreakOn
Sets the BREAK condition for the device.
[[File:]] -
Handle
- BYTE
FT_CreateDeviceInfoList
This function builds a device information list and returns the number of D2XX devices connected to the system. The list contains information about both unopen and open devices.
[[File:]] -
DevCount
Unsigned long array used to store the number of devices connected
- BYTE
FT_SetTimeouts
This function sets the read and write timeouts for the device.
[[File:]] -
Handle
[[File:]] -
ReadTimeout
Read timeout in milliseconds.
[[File:]] -
WriteTimeout
Write timeout in milliseconds.
- BYTE
FT_SetBitMode
Enables different chip modes.
[[File:]] -
Handle
- BYTE
Mask
Required value for bit mode mask. This sets up which bits are inputs and outputs. A bit value of 0 sets the corresponding pin to an input, a bit value of 1 sets the corresponding pin to an output.
- BYTE
Mode
0=Reset / 1=AsyncBB / 2=MPSSE / 4=SyncBB / 8=MCUHost / 16=FastOpto / 32=CBUS / 64=SyncFIFO
- BYTE
FT_SetRts
This function sets the Request To Send (RTS) control signal.
[[File:]] -
Handle
- BYTE
FT_GetDeviceInfoDetail
This function returns an entry from the device information list.
- ULONG
Index
Index of the entry in the device info list.
- ULONG
Flags
Pointer to unsigned long to store the flag value.
- ULONG
Type
Pointer to unsigned long to store device type.
- ULONG
ID
Pointer to unsigned long to store device ID.
- ULONG
LocID
Pointer to unsigned long to store the device location ID.
- BYTE
SerNum
Pointer to buffer to store device serial number as a null terminated string
- BYTE
Descript
Pointer to buffer to store device description as a null-terminated string
[[File:]] -
TempHandle
Pointer to a variable of type FT_HANDLE where the handle will be stored
- BYTE
FT_Close
Close an open device.
[[File:]] -
Handle
- BYTE
FT_ClrDtr
This function clears the Data Terminal Ready (DTR) control signal.
[[File:]] -
Handle
- BYTE
FT_Purge
This function purges receive and transmit buffers in the device.
[[File:]] -
Handle
[[File:]] -
Mask
Used to determine which buffer to purge, 1=Rx / 2=Tx / 3=Both
- BYTE
FT_GetQueueStatus
Gets the number of bytes in the receive queue.
[[File:]] -
Handle
[[File:]] -
RxQueueLength
Pointer to a variable of type DWORD which receives the number of bytes in the receive queue.
- BYTE
FT_SetDataCharacteristics
This function sets the data characteristics for the device.
[[File:]] -
Handle
- BYTE
WordLength
Number of bits per word - Must be 7 or 8
- BYTE
StopBits
Number of stop bits - Must be 1 or 2
- BYTE
Parity
Parity 0=None / 1=Odd / 2=Even / 3=Mark / 4=Space
- BYTE
FT_SetBreakOff
Resets the BREAK condition for the device.
[[File:]] -
Handle
- BYTE
FT_SetDivisor
This function sets the baud rate for the device. It is used to set non-standard baud rates.
[[File:]] -
Handle
- UINT
Divisor
Divisor.
- BYTE
FT_SetBaudRate
[[File:]] -
Handle
- ULONG
BaudRate
Baud rate.
- BYTE
FT_SetDtr
This function sets the Data Terminal Ready (DTR) control signal.
[[File:]] -
Handle
- BYTE
FT_Open
Open the device and return a handle which will be used for subsequent accesses.
[[File:]] -
Device
Index of the device to open. Indices are 0 based.
[[File:]] -
ft_Handle
Pointer to a variable of type FT_HANDLE where the handle will be stored. This handle must be used to access the device.
- BYTE
ScanFor232
Scans for a FTDI D2XX device, returnes true if at least one device was found.
[[File:]] -
FT_ResetDevice
This function sends a reset command to the device.
[[File:]] -
Handle
- BYTE
FT_SetChars
This function sets the special characters for the device.
[[File:]] -
Handle
- BYTE
EventCh
Event character.
- BYTE
EventChEn
0 if event character disabled, non-zero otherwise.
- BYTE
ErrorCh
Error character.
- BYTE
ErrorChEn
0 if error character disabled, non-zero otherwise.
- BYTE
A text label for the component's panel component.
Simulations
