Component: DAC (MCP49x1) (Analog Output)
Revision as of 21:05, 16 November 2021 by Wiki bot (talk | contribs)
Category Analog Output
DAC component
Component to drive a digital to analogue converter (DAC) IC from Microchip via an SPI interface. Compatible with MCP4901 (8-Bit), MCP4911 (10-Bit) and MCP4921 (12-Bit) devices.
SetOutput
Sets the output voltage of the DAC 8-Bit: Range 0-255 10-Bit: Range 0-1023 12-Bit: Range 0-4095
- UINT DAC_Value
The value to output to the DAC
ControlPins
Allows Shutdown (SHDN) and Latch (LDAC) pins to be controlled directly if enabled.
[[File:]] - Shutdown
0 = Shutdown Device, 1 = Device Active
[[File:]] - Latch
0 = Data output driven from DAC register, 1 = Data output locked
Disable
Disables the DAC output.
Enable
Enables the DAC Output.
- BYTE Channel
0=DAC Channel 0 , 1=DAC Channel 1
Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated.
WriteLEDs
Allows control of all 8-LEDs on the front of the Formula Flowcode.
- BYTE LED_Byte
Starts up the formula flowcode PWM for motor control and performs the wait for button press
DAC IC
Selects which DAC IC is connected and therefore the bit depth available.
Gain Option
Vref Pin Voltage
The reference voltage applied to the VREF pin.
Vref Voltage
Steps
Number of discrete output states available from the DAC.
Control Bits
Resolution
Voltage Resolution
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Use SHDN Pin
Allows the SHDN pin to be driven from an output pin on the microcontroller. If not used then tie the SHDN pin to VCC to allow the DAC to function.
Use LDAC Pin
Allows the LDAC pin to be driven from an output pin on the microcontroller. If not used then tie the LDAC pin to GND to allow the DAC to function.
Simulations
Simulate Comms
DAC Output Scope Traces
SPI Scope Traces
SPI Console Data
API
