Component: Base2dChart (Development)
Revision as of 10:34, 17 November 2021 by Wiki bot (talk | contribs)
Author Steve Tandy
Version 1.1
Category Development
Base2dChart component
A base component for creating 2d charts.
AddDataXYY1
Adds a data point for a ternary chart (3 axes) to the specified series.
- BYTE Series
Which series to add to (1-8)
[[File:]] - xValue
The value on the first axis
[[File:]] - yValue
The value on the second axis
[[File:]] - zValue
The value on the third axis
AddData
Adds a data point (y-value only) to the specified series.
- BYTE Series
[[File:]] - Value
The data point value
AddDataXY
Adds a data point (x and y values) to the specified series.
- BYTE Series
[[File:]] - xValue
The x coordinate for the data point
[[File:]] - yValue
The y coordinate for the data point
AddCatData
- BYTE Series
- STRING Category
[[File:]] - Value
SetMode
Select the mode of operation
[[File:]] - bUseArrays
True if data points are added to a hidden buffer; False if data is drawn directly onto chart.
ClearData
Removes all datapoints from the chart.
SetValue
Sets the component to the specified value.
[[File:]] - value
A new value for the component.
RefreshChart
Redraws the chart.
GetData
Gets a data point from the specified series.
- BYTE Series
[[File:]] - Index
The data point index (1 - 32767)
[[File:]] - Return
AddDataCXYY1
Adds a data point to a bubble chart.
- BYTE Series
- STRING Category
[[File:]] - Y
Y coordinate
[[File:]] - X
X coordinate
[[File:]] - Value
The value of the data point
GetList
Returns CHANNEL or PRESCALE list from the FCD and updates the internal property
- STRING Name
- STRING Return
InitRXConfig
Initialization setting for RX Buffer Config
- BYTE Buffer
Buffer Number (0 or 1)
- BYTE Value
Config data byte
Uninit
Uninitialises the CAN, freeing its connections for general use
GetList
Get the Filter List of the Named Property
- STRING Name
- STRING Return
GetRxIdent
Generic function to get the received message Identifier.
- BYTE buffer
- ULONG Return
SetRxFilterStd
Sets the 16-bit filter as a bit-mask of the standard ID for received messages The messages are accepted if (StdID & Mask) == Filter
- BYTE Filter
Filter number
- BYTE Hi
The high byte (bits 8-15) of the ID
- BYTE Lo
The low byte (bits 0-7) of the ID
SetRxFilterExd
Sets the 32-bit filter as a bit-mask of the extended ID for received messages The messages are accepted if (ExtID & Mask) == Filter
- BYTE Filter
Send filter: 0 to 3
- BYTE ID3
The high byte (bits 24-31) of the ID
- BYTE ID2
The mid-high byte (bits 16-23) of the ID
- BYTE ID1
The mid-low byte (bits 8-15) of the ID
- BYTE ID0
Categories
Y Values
X Values
Z Values
Title
Style
Stacking
Fill Gradient
Transparency
Data Between Ticks
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Name
Show Grid
Auto-scale
Start
End
Logarithmic
Scalable
Show
Show Category
Show Value
Show Percentage
Show Series
Angle
Position
Position
Draw Border
Select Series
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
Series Name
Visible
Secondary Axis
Line Style
Line Type
Line Width
Shadow
Fill
Show Marker
Marker Shape
Marker Size
nSeries
dXVal
dYVal
dY1Val
sYCat
bUseArrays
fnAddCatValue
fnClearData
fnAddValueCXYY1
fnAddValueXYY1
fnGetValue
fnGetValueXY
fnRefreshChart
Simulations
