Component: FTDI (FT800) (FT800) (Misc)
Revision as of 10:35, 17 November 2021 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 2.0
Category Misc
FTDI (FT800) component
The FT800 provides a powerful feature set in a small package to create dynamic HMI interfaces. The device supports line by line graphics rendering to 1/16 of a pixel on displays with resolution up to 512 x 512 with 262K colours. The chip includes a touch controller for sensing touch feedback from a TFT display with a resistive touch panel as well as a sound synthesizer and audio playback with a PWM output to drive a speaker.
Fc9-comp-macro.png IncrementCommandOffset
Adds commandSize to the currentOffset. Checks for 4K ring-buffer offset roll-over
Fc9-u16-icon.png - UINT currentOffset
graphics processor command list pointer
Fc9-u8-icon.png - BYTE commandSize
number of bytes to increment the offset
Fc9-comp-macro.png MemRead16
Reads a single unsigned int from the FT800 internal address space
Fc9-u32-icon.png - ULONG Address
Fc9-comp-macro.png MemRead8
Reads a single data byte from the FT800 internal address space
Fc9-comp-macro.png MemRead32
Reads a single unsigned long from the FT800 internal address space
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png MemWrite16
Writes a unsigned int value to the FT800 internal address space
Fc9-u16-icon.png - UINT Data
Fc9-comp-macro.png MemWrite8
Writes a byte value to the FT800 internal address space
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png CommandWrite
Sends FT800 command
Fc9-u8-icon.png - BYTE Command
Fc9-comp-macro.png MemWrite32
Writes a unsigned long value to the FT800 internal address space
Fc9-u32-icon.png - ULONG Data
Fc9-comp-macro.png Initialise
System initialization routines. Executed once on reset. Returns 0 if device not detected or 1 if device is correctly initialised.
Fc9-comp-macro.png ReadFileLength
Returns the number of bytes in the current sector that are used by the current open file. Return = 512 - Sector is filled with file data Return < 512 - Last sector of the file, Retval specifies how many bytes of data are remaining in the sector
[[File:]] - Return
Fc9-comp-macro.png OpenFile
Searches for and opens a file for reading or writing from within the current directory on the disk. Returns 0 for success.
8.3 filename of the file we are trying to open e.g. "file.txt"
Fc9-comp-macro.png WriteFileSector
Fc9-comp-macro.png AppendStringToFile
Fc9-string-icon.png - STRING Data_String
Fc9-comp-macro.png ReadFileSize
Reads the entire size of the current file in bytes.
[[File:]] - Return
Overwrites the current sector on the memory card with the contents of the local sector buffer. See write_byte_to_buffer function. Return = 0 - File sector written successfully. Return > 0 - File sector write error
Fc9-comp-macro.png SetFileIndex
Sets the current file index and used to switch between several open file streams. Default = 0.
Fc9-u8-icon.png - BYTE File_Index
File index ranges from 0 to (Max Concurrent Files - 1)
Adds the contents of the data string parameter to the end of the currently open file. Returns 0 for success.
Data to append to the end of the file
Fc9-comp-macro.png SetByte
Fc9-u32-icon.png - ULONG Int
Fc9-u8-icon.png - BYTE Ix
Fc9-u8-icon.png - BYTE Value
Fc9-comp-macro.png GetByte
Gets a byte from an int
Fc9-comp-macro.png SetTimeAndDate
Sets the current time and date. Time = (Hour << 11) + (Min << 5) + (Sec >> 1) Date = (YearFrom1980 << 9) + (Month << 5) + (Day) Additional details can be found here: http://www.maverick-os.dk/FileSystemFormats/FAT16_FileSystem.html#TimeFormat
Fc9-u16-icon.png - UINT Time
Sets the current Time in FAT Time format hhhhhmmmmmmsssss - S=Secs/2
Fc9-u16-icon.png - UINT Date
Sets the current Date in FAT Date format yyyyyyymmmmddddd - Y=Years since 1980
Attempts to communicate with the SD card and if successful sets up the file system. Returns 0 for success.
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png Power Pin
Fc9-type-5-icon.png CS Pin
Fc9-type-21-icon.png Width
Active width of LCD display
Fc9-type-21-icon.png Height
Active height of LCD display
Fc9-type-21-icon.png HCycle
Total number of clocks per line
Fc9-type-21-icon.png HOffset
Start of active line
Fc9-type-21-icon.png HSync0
Start of horizontal sync pulse
Fc9-type-21-icon.png HSync1
End of horizontal sync pulse
Fc9-type-21-icon.png VCycle
Total number of lines per screen
Fc9-type-21-icon.png VOffset
Start of active screen
Fc9-type-21-icon.png VSync0
Start of vertical sync pulse
Fc9-type-21-icon.png VSync1
End of vertical sync pulse
Fc9-type-21-icon.png PixelClock
Pixel Clock
Fc9-type-21-icon.png Swizzle
Define RGB output pins
Fc9-type-21-icon.png Clock Polarity
Define active edge of PCLK
Fc9-conn-icon.png Simulations
Fc9-type-16-icon.png API
