Component: FCD helper (Matrix Tools)
| Author | Matrix Ltd |
| Category | Matrix Tools |
FCD helper component
A helper control to query the current Flowcode definition XML file.
| GetStrListItem | |
| Gets a list item from a string index and a textual name Suitable for writing to a property filter Newline is added | |
| Index | |
| Name | |
| GetIntListItem | |
| Gets a list item from an integer and a textual name Suitable for writing to a property filter Newline is added | |
| Index | |
| Name | |
| GPS_Read_Over_Ground | |
| [[File:]] - | Return |
| GPS_Read_UTC_Date | |
| unit | |
| MIAC_Module_SetData | |
| Count | |
| D0 | |
| D1 | |
| D2 | |
| D3 | |
| D4 | |
| D5 | |
| GPS_HorizontalDilutionOfPrecision | |
| FAT_ScanCurrentFolder | |
| idx | |
| type | |
| Scan type | |
| MIAC_Module_Init | |
| CAN_ID | |
| MIAC_Module_GetData | |
| Index | |
| GPS_Is_Data_Valid | |
| FAT_AppendStringToFile | |
| Text | |
| MIAC_Module_Message | |
| CAN_ID | |
| CMD_ID | |
| MIAC_Module_WR | |
| CAN_ID | |
| CMD_ID | |
| [[File:]] - | Count |
| [[File:]] - | Start |
| [[File:]] - | More |
| FAT_OpenFolder | |
| Folder | |
| LED_Control | |
| Sets the indicator LED On (State=1) or Off (State=0) | |
| State | |
| FAT_MoveToNextFileSector | |
| force | |
| force next sector | |
| FAT_ReadByteFromScan | |
| idx | |
| GPS_Read_NumberOfSatellites | |
| FAT_ReadFileLength | |
| FAT_CreateFile | |
| Filename | |
| MIAC_Module_PushData | |
| Data | |
| GPS_Read_VerticalDilutionOfPrecision | |
| FAT_WriteFileSector | |
| GPS_Read_Altitude | |
| DigitalOutput | |
| Set a Terminal Output to High (Value=1) or Low (Value=0) | |
| Terminal | |
| Value | |
| FAT_ReadByteFromBuffer | |
| address | |
| MIAC_Module_GetAck | |
| CAN_ID | |
| CMD_ID | |
| TimeOut | |
| FAT_WriteByteToBuffer | |
| address | |
| data | |
| FAT_ReadFileSector | |
| FAT_DeleteFile | |
| Filename | |
| AnalogInput | |
| Read the ADC value of a Terminal Returns 12 bit ADC reading | |
| Terminal | |
| Terminal number to be read | |
| Initialize | |
| Forces a software reset on the module | |
| GPS_Read_UTC_Time | |
| unit | |
| DigitalInput | |
| Read the value of a terminal | |
| Terminal | |
| PWM_SetDuty | |
| Sets the PWM Duty cycle on Channel 1 or 2 | |
| Channel | |
| PWM Channel 1 or 2 | |
| Duty | |
| Duty cycle (8 bit value) | |
| MI2C_Start | |
| DigitalInput | |
| Terminal | |
| UART_SendChar | |
| Character | |
| EncoderReset | |
| Resets the motor encoder counters | |
| LCDVerbose | |
| Allows the LCD to automatically report the API commands as they get processed. Default - verbose on | |
| State | |
| 0=Off 1=On | |
| SetProp | |
| Allows the COM port property to be set from a parent component. | |
| PropName | |
| PropVal | |
| CardInit | |
| Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK | |
| GetProp | |
| Allows the property filter for the COM port list to be copied to a parent component. | |
| PropName | |
| LCDClear | |
| Clears the LCD | |
| Properties | |
| Connections | |
| Simulations |
