Component: API (Interface Board) (API Slave Devices)
Revision as of 10:37, 17 November 2021 by Wiki bot (talk | contribs)
Category API Slave Devices
API (Interface Board) component
Connects to an Interface Board running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART / DAC / Servo See Instructables for open source project files.
Direct Slave Access
Here is a simple demo to switch on and off digital pin 5.
Simple Interface Board Demo
Rapid Development - Virtualised SPI
A feature of the App Developer Slave interface is to use the component for rapid development.
The App Developer Slave hardware can be used to take communications from the Flowcode simulation and transfer them to a real world device allowing for easy code generation and test without having to download to a target microcontroller device.
The CS pin and SPI Prescaler are set via the properties of the Injector component.
The SPI Master component is linked to the Injector component via the Injector property.
The Injector component is linked to the App Developer Slave component via the App Developer Slave property.
Interface Board App Developer Slave SPI Demo
Rapid Development - Virtualised I2C
The I2C Master component is linked to the Injector component via the Injector property.
Interface Board App Developer Slave I2C Demo
Rapid Development - Virtualised UART
The Baud rate and optional RS485 Properties are set via the properties of the Injector component.
The UART component is linked to the Injector component via the Injector property.
Interface Board App Developer Slave UART Demo
I2CInitialise
- BYTE Channel
- BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
IOGetInputPin
- BYTE Pin
Range: 0-17
[[File:]] - Return
UARTBaud
- BYTE Channel
- BYTE Rate
ADCSample8
Reads the voltage present on an Alanog pin as an 8-bit value range 0-255
- BYTE ADCChannel
Range: 0-5
I2CTransReceive
- BYTE Channel
- BYTE Data
Data variable to receive into
- UINT Count
Number of bytes to receive
UARTInitialise
- BYTE Channel
UARTCheckRX
- BYTE Channel
I2CRestart
- BYTE Channel
WIFIIsConnected
Checks to see if the WIFI is active and connected
[[File:]] - Return
PWMDisable
Disable a PWM output
- BYTE Channel
Range: 0-1
I2CStart
- BYTE Channel
SPITransfer
- BYTE Channel
- BYTE DataOut
I2CReceive
- BYTE Channel
[[File:]] - Last
I2CStop
- BYTE Channel
WIFISetSSID
Assign the SSID and password for the network you wish to connect the board to. Stores the parameters into ROM for later USB free setup.
- STRING SSID
Name of the network you wish to connect to
- STRING Password
ServoDisable
Disable a Servo output
- BYTE Channel
Range: 0-5
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
ServoEnable
Enable a Servo output
- BYTE Channel
Range: 0-5
ADCSample10
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023
- BYTE ADCChannel
Range: 0-5
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
I2CTransInit
- BYTE Channel
- BYTE DeviceAddress
7-bit Device Address
- BYTE Baud
IOSetOutputPin
- BYTE Pin
Range: 0-17
[[File:]] - State
Range: 0-1
ServoSetPosition8
Sets the position as an 8-bit value
- BYTE Channel
Range: 0-1
- BYTE Position
Range: 0-255
UARTReceive
- BYTE Channel
SPIInitialise
- BYTE Channel
WIFIGetIP
Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI, Use the WIFIIsConnected first to check the WIFI is active.
- STRING Return
I2CSend
- BYTE Channel
- BYTE DataOut
[[File:]] - Return
UARTSend
- BYTE Channel
- BYTE Data
PWMSetPrescaler
- BYTE Prescaler
PWMSetDuty8
- BYTE Channel
Range: 0-1
- BYTE Duty
Range: 0-255
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-1
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
LCDClear
Clears the MIAC display
LCDClear
Clears the LCD
Connection Type
Auto Detect Port
Allows the component to auto detect the interface board COM port. Requires the latest Flowcode serial comms DLL to function correctly.
Network Interface
Some computers may have several network interfaces such as ethernet ports and wifi access. Select the correct network interface for the network you wish to connect to. Use the IP address to confirm you are connected to the right network.
Local IP Address
IP Address of the selected network interface.
Board IP
IP Address of the device we want to control
Auto Detect IP
Allows a device connected to the same subnet as the local IP address to be automatically detected. Scan may take a few minutes. Console reports progress.
Scan Results
Lists the IP addresses found during the last scan, Overwrites the selected WIFI IP property when changed.
Scan Start
Address to set the scan start point. For example 10 might generate 192.168.1.10 depending on your IP setting. Scan then proceeds from there so for example 11, 12, 13, ..., 254, 255. Default 0
End Scan
Decides how the scan is terminated
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
SERVO
Console Log
Create an automatic console log of the commands sent to the device
Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns ASCII mode allows serial data to be shown in raw text form, other commands are shown as in the Command Log mode
Show Raw
Shows the raw data stream via a console window
Simulations
