Component: Modbus Slave (SCADA) (Comms: System)
| Category | Comms: System |
Modbus Slave (SCADA) component
Modbus component for creating Modbus compatible slave hardware via RS232 or RS485.
| ReadHoldingRegister | |
| Reads the value of a single holding register. | |
| Address | |
| Coil Address | |
| SetCoil | |
| Sets the state of a single digital coil. | |
| Address | |
| Coil Address | |
| State | |
| 0=off, 1=on | |
| SetDigitalInput | |
| Sets the state of a single digital input. | |
| Address | |
| Coil Address | |
| State | |
| 0=off, 1=on | |
| ChangeFrameType | |
| Default frame type is the type set in the component properties. | |
| Type | |
| 0 = Modbus RTU / 1 = Modbus ASCII | |
| SetHoldingRegister | |
| Sets the state of a single holding register. | |
| Address | |
| Coil Address | |
| Value | |
| Analogue Value range 0 - 65535 | |
| ReadAnalogInput | |
| Reads the value of a single analogue input. | |
| Address | |
| Coil Address | |
| GetLastIncoming | |
| Gets a value from the last incoming command. Index 0 = 0 Read / 1 Write Index 1 = 0 Coils / 1 DigInput / 2 AnInput / 3 Register Index 2 = Address Index 3 = Number | |
| SetAnalogInput | |
| Sets the state of a single analogue input. | |
| Address | |
| Coil Address | |
| Value | |
| Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0. | |
| ReadFileSize | |
| Reads the entire size of the current file in bytes. | |
| SetTimeAndDate | |
| Sets the current time and date. Time = (Hour << 11) + (Min << 5) + (Sec >> 1) Date = (YearFrom1980 << 9) + (Month << 5) + (Day) Additional details can be found here: http://www.maverick-os.dk/FileSystemFormats/FAT16_FileSystem.html#TimeFormat | |
| Time | |
| Sets the current Time in FAT Time format hhhhhmmmmmmsssss - S=Secs/2 | |
| Date | |
| Sets the current Date in FAT Date format yyyyyyymmmmddddd - Y=Years since 1980 | |
| Attempts to communicate with the SD card and if successful sets up the file system. Returns 0 for success. | |
| ReadAnalogInput | |
| Reads a single digital input. | |
| Channel | |
| LCDClear | |
| Clears the MIAC display | |
| LCDClear | |
| Clears the LCD | |
