Component: Temperature Infrared (Grove 101020062) (Environmental)
| Version | 1.2 |
| Category | Environmental |
Temperature Infrared component
The Grove Infrared Temperature Sensor allows none contact measurement of temperatures ranging from -10 to 100 degrees C.
| MeasureSurTemp | |
| Measures the surrounding ambient temperature, | |
| [[File:]] - | Return |
| MeasureObjectTemp | |
| Measures the temperature of the targetted object | |
| GetADCValue | |
| Gets the raw ADC input value for the IR receiver | |
| Initialise the component by loading the default calibration table | |
| Initialise the sensor configuration as set by the component properties | |
| Initialises the component ready for I2C communications | |
| Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
| SimSetGyro | |
| Allows the XYZ slider values to be set via the simulation | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
| UpdateAccelerometerData | |
| Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
| SimSetCompass | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
| IOSetOutputPin | |
| Pin | |
| Range: 0-29 | |
| [[File:]] - | State |
| Range: 0-1 | |
| UARTReceive | |
| Channel | |
| OneWireScanBus | |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
| Channel | |
| SPIInitialise | |
| Channel | |
| OneWireReceiveByte | |
| Receives a byte from the one wire bus a bit at a time | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| UARTSend | |
| Channel | |
| Data | |
| OneWireGetDeviceCount | |
| Returns the number of devices found by the last ScanBus operation. | |
| Channel | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Range: 0 - 11 | |
| Prescaler | |
| Period | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-11 | |
