| Author
Matrix Ltd
| Version
3.0
| Category
Runtime Tools
COM Port component
Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial.
Auto Detect Port Number
This example auto detects and opens a COM Port based on preassigned USB Identifiers VID/PID.
For a known device the VID and PID can be found via Windows device manager.
Auto Detect Example
ReceiveByte
| Attempts to receive a byte using the COM port No valid return data is provided by the timeout value property.
- UINT
Timeout
| Time to wait for incoming data in milliseconds
- UINT
ConfigureConsole
- BYTE
Status
SendString
| Sends an string of characters to the COM port.
- STRING
Data
| Data byte array to send
ReceiveINTArray
| Receives an array of 16-bit INT/UINT values and returns the number of values received.
- UINT
Data
| Array to store the incoming data
- BYTE
NumValues
| Maximum number of values to try and receive
| [[File:]] -
MSBfirst
| 0=Least significant byte first, 1=Most significant byte first
- BYTE
Timeout
| Max amount of time in ms to wait between bytes
- BYTE
ReceiveNumber
| Attempts to receive a number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE
Timeout
| Max time in ms to wait in between bytes
| [[File:]] -
IgnoreData
| 0=Dont ignore any data, 1=Ignore any initial none numeric data
| [[File:]] -
SendBinary16Bit
| Sends out a 16-bit binary value split across two bytes.
- UINT
Value
| [[File:]] -
MSBfirst
SendINTArray
| Transmits an array of 16-bit INT/UINT values via the UART peripheral
- UINT
Data
| Data to transmit
- BYTE
NumValues
| Number of 16-bit values to send from the array
| [[File:]] -
MSBfirst
SendNumber
| Sends out a number as an ASCII String from the UART interface.
| [[File:]] -
Number
ReceiveBinary32Bit
| Receives a binary 32-bit value split across four bytes.
| [[File:]] -
MSBfirst
- BYTE
Timeout
- ULONG
ClosePort
| Closes the currently open COM port, ending communications and allowing it to be accessed via another application.
ReceiveBinaryFloat
| Receives a binary 32-bit floating point value split across four bytes.
| [[File:]] -
MSBfirst
- BYTE
Timeout
| [[File:]] -
SendByte
| Sends a single byte to be sent out via the COM port.
- BYTE
Data
SetDTRState
| Allows the DTR signal to be enabled or disabled.
- BYTE
State
| A value of 0 disables the DTR, 1 or above willl enable the DTR.
ScanForDeviceID
| Checks to see if a device VID/PID string is present and returns the COM port number. Returns 0 if device not found.
- STRING
HWID
| Example: "VID_12BF&PID_0101"
- BYTE
GetConsoleHandle
| Gets the handle to the console allowing data displaying on the panel etc.
| [[File:]] -
SendByteArray
| Sends an array of bytes to the COM port.
- BYTE
Data
- UINT
Length
| Number of bytes to send
ReceiveBinary16Bit
| Receives a binary 16-bit value split across two bytes.
| [[File:]] -
MSBfirst
- BYTE
Timeout
- UINT
ReceiveFloat
| Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE
Timeout
| [[File:]] -
IgnoreData
| [[File:]] -
SendFloat
| Sends out a floating point number as an ASCII String from the UART interface.
| [[File:]] -
Number
SendHexNumber
| Sends out a number as an ASCII hexadecimal String from the UART interface.
- ULONG
Number
- BYTE
NumChars
| Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
| [[File:]] -
Prefix
| Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
SetFlowControl
| Allows the Flowcontrol signals to be enabled or disabled.
- BYTE
State
| A value of 0 disables flow control, 1 or above willl enable flow control.
OpenPort
| Opens the currently selected COM port, allowing data to be sent and received.
ReceiveHexNumber
| Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
- BYTE
Timeout
| [[File:]] -
IgnoreData
| [[File:]] -
Prefix
| Look for prefix before receiving, 1=0xFF, 0=FF
- ULONG
SetProp
| Allows the COM port property to be set from a parent component.
- STRING
PropName
- ULONG
PropVal
SendBinary32Bit
| Sends out a 32-bit binary value split across four bytes.
- ULONG
Value
| [[File:]] -
MSBfirst
SendBinaryFloat
| Sends out a 32-bit binary floating point value split across four bytes.
| [[File:]] -
Value
| [[File:]] -
MSBfirst
GetProp
| Allows the property filter for the COM port list to be copied to a parent component.
- STRING
PropName
- STRING
ReceiveByteArray
| Attempts to receive an array of bytes using the COM port Returns the number of bytes received.
- BYTE
Data
- UINT
MaxLength
| Max number of bytes to try and read
- UINT
Timeout
- UINT
ReceiveString
| Attempts to receive an string using the COM port Returns the number of bytes received.
- UINT
Timeout
- UINT
MaxLength
- STRING
PWMEnable
| Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE
EnableMask
| Range 0-63 or 0b00000 to 0b111111
GetProp
- STRING
PropName
- STRING
COM Port
| Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
| When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Baud
| Baud rate passed to the COM port to control the rate of data.
Timeout Value
| Value to specify what is returned when no incoming receive data is present.
Auto Close
| Auto close the port on Sim stop event
Simulations
