Component: Speech (RealSpeak) (Indicators)
Revision as of 10:39, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.2
Category Indicators
Speech (RealSpeak) component
Advanced speech engine allowing realistic text to speech in multiple languages using the RealSpeak voice engine. Available in simulation only.
Fc9-comp-macro.png Speak
Simulation only call to allow the computer to speak using the RealSpeak voice engine. Languages need to be downloaded and installed then selected using the Voice property.
Fc9-string-icon.png - STRING DataString
Fc9-comp-macro.png GetTag
Gets the tag ID returned as a byte array. Must be called after CheckForTag has returned true. Byte array variable should be at least 6 bytes long.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png IsKnownID
Checks to see if the last tag read by CheckForTag is saved into memory. Returns true if tag is stored in memory.
[[File:]] - Return
Fc9-comp-macro.png Initialise
Initialises the I2C bus ready for communications with the module. Wipes the tag ID storage ready for data to be stored.
Fc9-comp-macro.png OpenPort
Opens the currently selected COM port, allowing data to be sent and received.
Fc9-comp-macro.png SetProp
Allows the COM port property to be set from a parent component.
Fc9-string-icon.png - STRING PropName
Fc9-u32-icon.png - ULONG PropVal
Fc9-comp-macro.png GetProp
Allows the property filter for the COM port list to be copied to a parent component.
[[File:]] - Return
Fc9-comp-macro.png SendByteArray
Sends an array of bytes to the COM port.
Data byte array to send
Number of bytes to send
Fc9-comp-macro.png ReceiveBinary16Bit
Receives a binary 16-bit value split across two bytes.
[[File:]] - MSBfirst
0=Least significant byte first, 1=Most significant byte first
Fc9-u8-icon.png - BYTE Timeout
Max amount of time in ms to wait between bytes
Fc9-comp-macro.png ReceiveFloat
Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
Max time in ms to wait in between bytes
[[File:]] - IgnoreData
0=Dont ignore any data, 1=Ignore any initial none numeric data
[[File:]] - Return
Fc9-comp-macro.png SendFloat
Sends out a floating point number as an ASCII String from the UART interface.
[[File:]] - Number
Fc9-comp-macro.png SendHexNumber
Sends out a number as an ASCII hexadecimal String from the UART interface.
Fc9-u32-icon.png - ULONG Number
Fc9-u8-icon.png - BYTE NumChars
Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
[[File:]] - Prefix
Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
Fc9-comp-macro.png SetFlowControl
Allows the Flowcontrol signals to be enabled or disabled.
Fc9-u8-icon.png - BYTE State
A value of 0 disables flow control, 1 or above willl enable flow control.
Fc9-comp-macro.png ReceiveHexNumber
Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
[[File:]] - Prefix
Look for prefix before receiving, 1=0xFF, 0=FF
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png SendBinary32Bit
Sends out a 32-bit binary value split across four bytes.
Fc9-u32-icon.png - ULONG Value
Fc9-comp-macro.png SendBinaryFloat
Sends out a 32-bit binary floating point value split across four bytes.
[[File:]] - Value
Fc9-comp-macro.png ReceiveByteArray
Attempts to receive an array of bytes using the COM port Returns the number of bytes received.
Fc9-u16-icon.png - UINT MaxLength
Max number of bytes to try and read
Fc9-u16-icon.png - UINT Timeout
Time to wait for incoming data in milliseconds
Fc9-comp-macro.png ReceiveString
Attempts to receive an string using the COM port Returns the number of bytes received.
Fc9-comp-macro.png PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
Fc9-u8-icon.png - BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
Fc9-type-16-icon.png Voice
RealSpeak selected voice - Download and install RealSpeak voices for more options.
Fc9-type-14-icon.png Rate
Voice speech rate - Default 1 - Range (0-100)
Fc9-conn-icon.png Simulations
