Component: Water Sensor (Grove 101020018) (101020018) (Environmental)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.0 |
Category | Environmental |
Water Sensor (Grove 101020018) component
The water sensor uses a 1M ohm pull-up resistor. The resistor will pull the sensor trace value high until a drop of water shorts the sensor trace to the ground trace. You can use it with an analog input pin to detect the amount of water in contact between the grounded and sensor traces.
GetIntValue |
Returns the analog reading as an integer value. | |
[[File:]] - | Return |
GetFloatValue |
Reads the analog value as a floating point value between 0 and 100 | |
