Component: Injector (API Digital Input) (Test Injectors)
Revision as of 11:04, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.2
Category Test Injectors
Injector (API Digital Input) component
Data injector to allow a physical digital input pin to be attached to a simulated component. The component will poll for any input state changes via SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly interface with a physical I/O pin.
InitialiseInjector
- STRING InjectorName
RxByteCount
Returns the number of bytes currently sat in the receive buffer.
TxByte
- BYTE DataByte
RxByte
GetConsoleHandle
[[File:]] - Return
API Slave
Number of Pins
Specifies the number of pins the component can monitor and control.
Poll Rate
Simulation I/O Pin
Pin monitored by the simulation
SCADA Slave Pin
Pin used by the connected SCADA Slave hardware
Simulation I/O Pin
SCADA Slave Pin
Simulation I/O Pin
SCADA Slave Pin
Simulation I/O Pin
SCADA Slave Pin
Simulation I/O Pin
SCADA Slave Pin
Simulation I/O Pin
SCADA Slave Pin
Simulation I/O Pin
SCADA Slave Pin
Simulation I/O Pin
SCADA Slave Pin
Simulations
