Component: Data Transfer (API SPI) ()
Revision as of 11:04, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.2
Category
Data Transfer (API SPI) component
Comms data injector to allow a SPI bus peripheral to be attached to a comms component. The component will forward any byte transactions through to a SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly drive a physical SPI bus.
Fc9-comp-macro.png InitialiseInjector
Fc9-string-icon.png - STRING InjectorName
Fc9-comp-macro.png TxByte
Fc9-u8-icon.png - BYTE DataByte
Fc9-comp-macro.png RxByte
[[File:]] - Return
Fc9-comp-macro.png ChangeState
Sets the state of the bus. SPI - Controls the chip select pin I2C - Controls the start/restart/stop status
Fc9-u8-icon.png - BYTE State
SPI: 0=CSLow, 1=CSHigh I2C: 0=Stop, 1=Start, 2=Restart
Fc9-type-17-icon.png SCADA Slave
Fc9-type-21-icon.png CS Pin Number
Digital I/O pin number to use for the CS pin
Fc9-type-21-icon.png SPI Prescaler
Sets the prescaler rate of the SPI bus. See the SCADA Slave SPIPrescaler macro for valid values,
Fc9-conn-icon.png Simulations
