API Sound.QueueEx
Jump to navigationJump to search<sidebar>API contents</sidebar> Queues a sound for playing, with the format provided
HANDLE Sounds
- The handle of the sound object to queue to
BYTE[] Data
- The array to play data from
ULONG ByteOffset
- The byte-offset in the array to start at
UINT SampleFormat
- Format of the samples
Typical values for this parameter:
| Type | Name | Description |
| LONG | Fmt_Signed8 | Source data is in the range -128 to 127 |
| LONG | Fmt_Unsigned8 | Source data is in the range 0 to 255 |
| LONG | Fmt_Signed16 | Source data is in the range -32768 to 32767 |
| LONG | Fmt_Unsigned16 | Source data is in the range 0 to 65535 |
| LONG | Fmt_Signed32 | Source data is a signed 32-bit value |
| LONG | Fmt_Unsigned32 | Source data is an unsigned 32-bit value |
| LONG | Fmt_Float32 | Source data is a 32-bit float from 0 to 1 |
| LONG | Fmt_Float64 | Source data is a 64-bit float from 0 to 1 |
| LONG | Fmt_Mono | Set this flag to set a single source element per sample |
| LONG | Fmt_Stereo | Set this flag to two source elements per sample |
ULONG Elements
- The number of sample elements to play
FLOAT RateMul
- A multiplier to the sounds sample rate
- The default value for this parameter is: 1
- Add to a calculation icon:
result = ::Sound.QueueEx(sounds, _arraydata, byteoffset, ::Sound.Fmt_Signed8, elements, ratemul)
