| Author
Matrix Ltd
| Version
1.0
| Category
Test Equipment
PicoScope component
A set of functions designed for interacting with a 2000 series Pico scope via simulation.
An example project showing the capabilities of the Velleman K8055D board combined with a Pico Technology series 2 scope.
Velleman and Picoscope Demo
ps2000_get_timebase
| Returns details associated with the selected timebase index
| [[File:]] -
Handle
| the handle of the required device.
| [[File:]] -
timebase
| The ps2000a API allows you to select any of 2 32 different timebases based on a maximum sampling rate of 1 GS/s.
| [[File:]] -
no_of_samples
| number of samples required
| [[File:]] -
time_interval
| time interval between readings at the selected timebase. Use NULL if not required.
| [[File:]] -
time_units
| [[File:]] -
oversample
| not used.
| [[File:]] -
max_samples
| on exit, the maximum number of samples available.
| [[File:]] -
ps2000_open_unit_progress
| This function checks on the progress of a request made to ps2000aOpenUnitAsync to open a scope.
| [[File:]] -
handle
| [[File:]] -
Progress
| [[File:]] -
ps2000_flash_led
| This function flashes the LED on the front of the scope without blocking the calling thread.
| [[File:]] -
handle
| handle of the scope device
| [[File:]] -
ps2000_stop
| This function stops the scope device from sampling data. If this function is called before a trigger event occurs, the oscilloscope may not contain valid data.
| [[File:]] -
Handle
| [[File:]] -
ps2000_get_unit_info
| This function retrieves information about the specified oscilloscope.
| [[File:]] -
Handle
| the handle of the device
- STRING
info_string
| unit information string
| [[File:]] -
string_length
| the maximum number of chars in the string
| [[File:]] -
info_line
| a number specifying what information is required. 0=DriverVersion / 1=USBVersion / 2=HardwareVersion / 3=VariantInfo / 4=BatchAndSerial / 5=CalDate / 6=KernelVersion / 7=DigHardwareVersion / 8=AnHardwareVersion
| [[File:]] -
ps2000_set_channel
| This function specifies whether an input channel is to be enabled, its input coupling type, voltage range, analog offset and bandwidth limit.
| [[File:]] -
handle
| Handle of the device
| [[File:]] -
channel
| the channel to be configured. The values are: 0=ChanA / 1=ChanB
| [[File:]] -
enabled
| whether or not to enable the channel. The values are: 0=Disable / 1=Enable
| [[File:]] -
dc
| the impedance and coupling type. Values: 0=AC / 1=DC
| [[File:]] -
range
| the input voltage range: 0=50mV / 1=100mV / 2=200mV / 3=500mV / 4=1V / 5=2V / 6=5V / 7=10V / 8=20V
| [[File:]] -
ps2000_get_times_and_values
| [[File:]] -
Handle
| [[File:]] -
times
| [[File:]] -
buffer_a
| [[File:]] -
buffer_b
| [[File:]] -
buffer_c
| [[File:]] -
buffer_d
| [[File:]] -
overflow
| [[File:]] -
time_units
| [[File:]] -
no_of_samples
| [[File:]] -
ps2000_set_trigger
| [[File:]] -
handle
| [[File:]] -
source
| [[File:]] -
threshold
| [[File:]] -
direction
| [[File:]] -
delay
| [[File:]] -
auto_trigger_ms
| [[File:]] -
ps2000_set_sig_gen_built_in
| sets up the signal generator to produce a signal from a list of built-in waveforms
| [[File:]] -
Handle
| Handle to the device
| [[File:]] -
Offset_uV
| the voltage offset, in microvolts, to be applied to the waveform
- ULONG
pk2pk_uV
| the peak-to-peak voltage, in microvolts, of the waveform
| [[File:]] -
waveType
| the type of waveform to be generated. 0=Sine / 1=Square / 2=Triangle / 3=RampUp / 4=RampDown / 5=Sinc / 6=Gaus / 7=HalfSine / 8=DC
| [[File:]] -
startFrequency
| the frequency that the signal generator will initially produce
| [[File:]] -
stopFrequency
| the frequency at which the sweep reverses direction or returns to initial
| [[File:]] -
increment
| the amount of frequency increase or decrease in sweep mode
| [[File:]] -
dwellTime
| the time for which the sweep stays at each frequency, in seconds
| [[File:]] -
sweepType
| whether the frequency will sweep from startFrequency to stopFrequency. 0=Up, 1=Down, 2=UpDown, 3=DownUp
- ULONG
sweeps
| produce number of cycles specified by shots
| [[File:]] -
ps2000_close_unit
| This function shuts down an oscilloscope.
| [[File:]] -
Handle
| The handle of the scope device to be closed
| [[File:]] -
ps2000_run_block
| This function starts collecting data in block mode.
| [[File:]] -
handle
| [[File:]] -
no_of_samples
| [[File:]] -
timebase
| [[File:]] -
oversample
| [[File:]] -
time_indisposed_ms
| [[File:]] -
ps2000_get_values
| This function returns block-mode data, with or without downsampling.
| [[File:]] -
Handle
| [[File:]] -
buffer_a
| Start point for data collection
| [[File:]] -
buffer_b
| Number of samples
| [[File:]] -
buffer_c
| Down sample ratio
| [[File:]] -
buffer_d
| Down sample mode : 0=None / 1=Aggregate / 2=Decimate / 4=Average
| [[File:]] -
overflow
| Flags to indicate if an overflow has occurred
| [[File:]] -
no_of_samples
| [[File:]] -
ps2000_ready
| [[File:]] -
Handle
| [[File:]] -
ps2000_open_unit_async
| This function opens a scope without blocking the calling thread.
| [[File:]] -
ps2000_open_unit
| Returns a handle to the opened unit Returns 0 if no unit found Returns -1 if unit failed to open
| [[File:]] -
Simulations
