Component: Ultrasonic (HCSR04) (Audio)
Revision as of 11:06, 17 November 2021 by Wiki bot (talk | contribs)
Category Audio
Ultrasonic component
This board has both an ultrasonic transmitter and receiver. When the Trig pin is set high for 10uS, the transmitter sends eight 40KHz pulses. The Echo pin goes high about 2ms later. The duration of the Echo pin is measure when it goes high, and a distance is then calculated based on the high duration. The distance of objects in a range of around 3cm to 2.75m can be determined.
FC6 Icon.png HC-SR04 Distance Sensor Demo.fcfx
Fc9-comp-macro.png GetDistance
Sends a pulse and processes the echo. Returns a object distance in cm
Fc9-type-5-icon.png OutputTrig Pin
Pin used for controlling the output pulse
Fc9-type-5-icon.png Input Echo Pin
ADC channel used to monitor the echo
Fc9-conn-icon.png Simulations
