Component: Temp / Humidity (SHT21) (Environmental)
Revision as of 11:06, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category Environmental
Temp / Humidity component
Humidity and temperature sensor using an SHT21 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
GetTemperatureReal
Return temperature reading as a float value in degrees C
[[File:]] - Return
GetTemperatureData
Returns the raw register pair value
GetTemperatureInt
Return temperature reading as an integer value in degrees C
[[File:]] - Return
GetHumidityInt
returns the relative Humidity reading as an integer value
[[File:]] - Return
GetHumidityReal
returns the Humidity reading as a float value
[[File:]] - Return
GetHumidityData
Initialises the component ready for I2C communications
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
API
Simulations
Simulation Comms
