Component: GLCD (SSD1306) (SSD1306) (Graphical Monochrome)
Revision as of 11:09, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Monochrome
GLCD (SSD1306) component
Graphical display component based on the SSD1306 monochrome graphical controller IC.
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
[[File:]] - Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
SetDisplayOrientation
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Pixel Width
Pixel Height
Interlaced
Offset X
Offset Y
Monochrome
Foreground Color
Background Color
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Chip Select (CS)
Chip select pin connection
Read / Write (R/W)
Reg Select (RS)
Data (SD)
Serial Clock (SCK)
Reset pin connection
Reset (RST)
Simulations
