Component: Indicator Gauge (Indicators)
| Author | Matrix Ltd |
| Version | 1.3 (Release) |
| Category | Indicators |
Indicator Gauge component
Simulation only round gauge/dial for SCADA applications. The range of values displayed is easily adjusted.
This component does not contain any downloadable macros
Simulation macro reference
GetValue
Get the current scale value - this will be the most recent value set using "SetValue", or from the most recent mouse click if the component is in "Control"
mode.
SetValue
Set the pointer to the given value on the scale. Returns the angle required to point at the given value.
- FLOAT Value
- The value on the scale to move the pointer to.
SetRange
Set the minimum and maximum values of the scale
- FLOAT Minimum
- Minimum value for the scale
- FLOAT Maximum
- Maximum value for the scale
Minimum
This property is of type Floating point and can be referenced with the variable name val_min.
Minimum value that the meter will show (fully counter-clockwise)
Maximum
This property is of type Floating point and can be referenced with the variable name val_max.
Maximum value that the meter will show (fully clockwsie)
Startup State
This property is of type Fixed list of ints and can be referenced with the variable name StartupState.
Sets the initial value when loading the project or when the runtime starts.
Default Value
This property is of type Floating point and can be referenced with the variable name DefaultValue.
The default value used on initialise or runtime start.
Show Title
This property is of type True or false and can be referenced with the variable name ShowTitle.
Decides if the component title is shown
Title Colour
This property is of type Color picker and can be referenced with the variable name TitleColour.
Title Label Color
Title Text
This property is of type Line of text and can be referenced with the variable name TitleText.
Title Label Text
Title Scale
This property is of type Floating point and can be referenced with the variable name TitleScale.
Controls the size of the title text on the panel, default 1.2
Show Label
This property is of type True or false and can be referenced with the variable name ShowLabel.
Decides if a label is shown detailing current setting of the control knob.
Label Colour
This property is of type Color picker and can be referenced with the variable name LabelColour.
Sets the label colour
Label Units
This property is of type Line of text and can be referenced with the variable name LabelUnits.
Adds a unit to the end of the label
Label Decimal Points
This property is of type Unsigned integer and can be referenced with the variable name LabelDecPoints.
Number of decinal points to draw on the label
Label Scale
This property is of type Floating point and can be referenced with the variable name LabelScale.
Sets the size of the label on the panel, default 1.0
Decimals
This property is of type Signed integer and can be referenced with the variable name dec_places.
Number of decimal places to show on the number labels.
Text Size %
This property is of type Signed integer and can be referenced with the variable name num_size.
Height of the number label text.
Font
This property is of type Font picker and can be referenced with the variable name num_font.
Font for the number labels.
Divisions
This property is of type Signed integer and can be referenced with the variable name marks_count.
Set the number of major scale divisions - these will be given number value labels.
Subdivisions
This property is of type Signed integer and can be referenced with the variable name marks_subdiv.
Number of smaller scale divisions in between the numbered ones.
BG Color
This property is of type Color picker with transparency and can be referenced with the variable name bg_color.
Colour for the meter background.
Positive Color
This property is of type Color picker and can be referenced with the variable name ink_color.
Colour for the number labels for greater than zero.
Negative Color
This property is of type Color picker and can be referenced with the variable name neg_color.
Colour for the number labels for value greater than zero.
Needle Color
This property is of type Color picker and can be referenced with the variable name NeedleColor.
