Component: String Label (Indicators)
Revision as of 16:23, 27 November 2018 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Indicators
Image String Label component
Allows a numeric label to be displayed on the user panel. Used for displaying the value of a variable during simulation runtime. Provides up to 5 customisable ranges to automatically alter the colour of the label based on the value.
This component does not contain any downloadable macros
Simulation macro reference
DisplayString
Displays a string value on the label.
<- STRING Value
Integer value to display
This parameter may be returned back to the caller
SetBackgroundColour
Allows the user to manually specify the default colour of the background.
LONG Colour
RGB colour in the hexadecimal form 0xBBGGRR, -1 for Transparent
SetForegroundColour
Allows the user to manually specify the default colour of the foreground text.
LONG Colour
Show Title
This property is of type True or false and can be referenced with the variable name ShowTitle.
Decides if the title is shown on the panel.
Title Text
This property is of type Line of text and can be referenced with the variable name Title.
Specifies the title displayed on the panel.
Title Scale
This property is of type Floating point and can be referenced with the variable name TitleScale.
Specifies the size of the title on the panel, default 1.2
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgColTitle.
Specifies the foreground colour of the title text
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgColTitle.
Specifies the background colour of the title text
Label Scale
This property is of type Floating point and can be referenced with the variable name LabelScale.
Specifies the scale of the label text, default 1.0
Colour Values
This property is of type Fixed list of ints and can be referenced with the variable name Range.
Allows ranges to be specified to automatically format the foreground and background colours based on the numeric value
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgCol.
The label foreground Text colour
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgCol.
The label background Surrounding colour
Value
This property is of type Line of text and can be referenced with the variable name Value1.
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgCol1.
The label foreground Text colour when in the specified range
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgCol1.
The label background highlight colour when in the specified range
Value
This property is of type Line of text and can be referenced with the variable name Value2.
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgCol2.
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgCol2.
Value
This property is of type Line of text and can be referenced with the variable name Value3.
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgCol3.
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgCol3.
Value
This property is of type Line of text and can be referenced with the variable name Value4.
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgCol4.
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgCol4.
Value
This property is of type Line of text and can be referenced with the variable name Value5.
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgCol5.
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgCol5.
