Component: Barometer (BME280) (Environmental)
Author | Matrix TSL |
Version | 1.3 |
Category | Environmental |
Barometer component
A small PCB surface mount barometric pressure sensor with a I2C bus interface. Pressure range 300 to 1100 hPa. Temperature range -40 to +85 °C. Works with I2C interface only.
BME280 Barometer plus Altitude v1.0
This example reads and displays the pressure, temperature & humidity.
If the pressure is increasing then Rise will be displayed.
Circuit Diagram
ReadPressureFloat |
Reads the pressure as a floating point value in Bars. Calls the ReadPressureRaw function and then converts to a meaningful value. | |
Return |
Reset |
Resets the device | |
Return |
I2C_Read_Register |
Reads a byte value from a register on the device | |
Address |
Return |
Forced_Read |
Return |
I2C_Write_Register |
Writes a byte value to a register on the device | |
Address |
Value |
Return |
ReadHumidityFloat |
Reads the humidity as a floating point value in percentage 0-100%. Calls the ReadHumidityRaw function and then converts to a meaningful value. | |
Return |
Uninit |
Uninitialse and release I2C resources | |
Return |
Initialise |
Starts up the I2C bus and initialises the pressure sensor ready for use. Returns 1 for a sucessful startup. Returns 0 for a failed startup or no device detected. | |
Return |
