| Author
Matrix Ltd
| Version
1.8
| Category
Graphical Monochrome
GLCD (SSD1305) component
Graphical display component based on the SSD1305 monochrome graphical controller IC.
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
SetDisplayOrientation
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
- BYTE
PixelColour
| 0=White, 1=Black
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
PixelColour
| 0=White, 1=Black
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Pixel Width
Pixel Height
H Offset
| Offset from the edge of the display, default 0.
Monochrome
Foreground Color
Background Color
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Chip Select (CS)
| Chip select pin connection
Read / Write (R/W)
Reg Select (RS)
Data (SD)
| LED backlight strobe pin connection
Serial Clock (SCK)
| Reset pin connection
Reset (RST)
| Instruction / Command pin connection
Simulations
