| Author | Matrix Ltd |
| Version | 1.3 |
GLCD (T6963C) component
A Graphical LCD component to drive displays fitted with a T6963C controller IC.
|   | ReadFontWidth |
|  - BYTE | Font |
|  - BYTE | Character |
|  - BYTE | Return |
|   | SetFontScaler |
|  - BYTE | ScaleX |
|  - BYTE | ScaleY |
|  - VOID | Return |
|   | PrintNumber |
|  - INT | Number |
|  - UINT | X |
|  - UINT | Y |
|  - BYTE | Font |
|  - BYTE | Transparent |
|  - VOID | Return |
|   | DrawLine |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
|   | DrawEllipse |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | XRadius |
|  - UINT | YRadius |
|  - BYTE | Solid |
|  - VOID | Return |
|   | Plot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
|   | SetDisplayOrientation |
|  - BYTE | Orientation |
|  - VOID | Return |
|   | BPlot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
|   | ReadFontStat |
|  - BYTE | Font |
|  - BYTE | Index |
|  - BYTE | Return |
|   | Print |
|  - STRING | Str |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - BYTE | Font |
|  - VOID | Return |
|   | ClearDisplay |
|  - VOID | Return |
|   | SetBackgroundColour |
| Specifies the colour of the background. |
|  - BYTE | Pixel_Colour |
| 0=White, 1=Black |
|  - VOID | Return |
|   | DrawCircle |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | Radius |
|  - BYTE | Solid |
|  - VOID | Return |
|   | SetForegroundColour |
| Specifies the colour of the foreground. |
| 0=White, 1=Black |
|  - VOID | Return |
|   | DrawRectangle |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - BYTE | Solid |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | Pixel Width |
|   | Pixel Height |
|   | Monochrome |
|   | Foreground Color |
|   | Background Colour |
|   | Color Bit Depth |
|   | Red Bit Depth |
|   | Green Bit Depth |
|   | Blue Bit Depth |
|   | Font Count |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Display Method |
| Chooses which method to use when drawing to the gLCD component The bitmap is the more common mode but may run slowly on some machines. The point cloud should run faster but may use more memory. |
|   | Connections |
|   | WR |
|   | RD |
|   | CE |
|   | CD |
|   | Reset |
|   | FS |
|   | Data Uses Port |
| Does the data bus use a whole 8-bit port if so then set the property to yes to speed up execution. Otherwise if the data bus uses individual pins then set the property to no. |
|   | Data Port |
|   | Simulations |
