Component: Ultrasonic (EBM019) (EBM Modules)
| Category | EBM Modules |
Ultrasonic component
This board has both an ultrasonic transmitter and receiver. The transmitter is driven by an on-board 40KHz oscillator which is enabled by the host microprocessor. The receiving sensor signal is amplified and provided as an analogue signal to be processed by a single channel ADC of the microprocessor. By measuring the time delay between enabling a transmit pulse and receiving an echo the distance of objects in a range of around 3cm to 3m can be determined.
SENSORS
Sample program using the EBM019 - Ultrasonic sensor.
Sends out a pulse and determines distance from time taken to receive reflection.
| GetDistance | |
| Sends a pulse and processes the echo. Returns a object distance in cm | |
| SetDelayTime | |
| Set the delay time before sampling for the echo, in microseconds | |
| delay | |
| delay time in microseconds | |
| SetDetectionValue | |
| Set the delta value for echo detection | |
| value | |
| trigger point for echo detection | |
| SetPulseWidth | |
| Set the output pulse width, in microsecond (0-255uS) | |
| pulse | |
| width of pulse in microseconds | |
| Setup the device. This sets the control output to logic 0 | |
