Component: Bitmap Drawer (Displays: Graphical)
Revision as of 15:45, 16 February 2017 by BenR (talk | contribs) (XML import BR)
Version 1.2 (Release)
Category Displays: Graphical
Image Bitmap Drawer component
A component to simplify the process of drawing bitmap images to a graphical display. Stores the bitmap image inside a ROM look up table. Compatible with 24-bit Bitmaps and Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Use multiple BitmapDrawer components for multiple bitmap images.
Here is an example which loops drawing a monochrome and 24-bit bitmaps to the EBM001 graphical display. Bitmap Drawer Demo The bitmap files used in the example can be found here.
File:BitmapDrawerDemo.zip
Here is another example which overlays several monochrome images to give the impression of animation. Shows a pair of eyes, which can randomly and momentarily look left, right or blink. Bitmap Drawer Demo 2 The bitmap files used in the example can be found here.
File:BitmapDrawerDemo2.zip
Display_BMP_With_Transparency
Draws the stored bitmap image onto the display at the coordinates specified.
The coordinates specify the upper left corner of the image.
Skips over any pixels containing the transparent colour.
UINT X
UINT Y
BYTE TransR
Red Colour Byte 0-255
BYTE TransG
Green Colour Byte 0-255
BYTE TransB
Blue Colour Byte 0-255
GetHeight
Returns the height of the loaded bitmap file in pixels.
This macro has no parameters
UINT
GetWidth
Returns the width of the loaded bitmap file in pixels.
UINT
Display_BMP
Draws the bitmap image from ROM onto the display at the corrdinates X and Y.
UINT X
X Axis coordinate, specifies the location of the left edge of the bitmap image
UINT Y
Y Axis coordinate, specifies the location of the top edge of the bitmap image
Simulation macro reference
gLCD Object
This property is of type Panel object and can be referenced with the variable name glcd_obj.
Graphical LCD Object to draw the bitmap image to
Bitmap File
This property is of type Filename and can be referenced with the variable name bitmap_file.
Bitmap file you wish to embed into the program
File Colour Depth
This property is of type Unsigned integer and can be referenced with the variable name ColourDepth.
Number of bits per pixel.
Currently the component only supports bitmap files with 1-bit or 24-bit colour depth.
File Length
This property is of type Unsigned integer and can be referenced with the variable name file_Len.
The number of bytes of ROM the bitmap file will consume.
You can vie wthe number of ROM bytes available on your target device using the Device Helper component.
File Width
This property is of type Unsigned integer and can be referenced with the variable name FileWidth.
Width of the bitmap file in pixels
File Height
This property is of type Unsigned integer and can be referenced with the variable name FileHeight.
Height of the bitmap file in pixels
Data Offset
This property is of type Unsigned integer and can be referenced with the variable name DataOffset.
Offset in the file where the bitmap pixel data starts
ColourDisplay
This property is of type True or false and can be referenced with the variable name Colour_Display.
Automatically detects if the graphical LCD object is colour or monochrome
