Component: Grey Code Encoder (General Input)
Revision as of 17:47, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.4
Category General Input
Grey Code Encoder component
Grey Code Encoder component implements a rotary encoder connected to a defined number of pins Grey Code Encoders provide absolute positioning rather than incremental positioning.
Please click here for the component source code: FC_Comp_Source_Grey_Code_Encoder_2dgi.fcfx
Fc9-comp-macro.png ReadAbsoluteAngle
Reads the absolute angular position of the motor. Returns a floating point value representing the angle of the encoder.
Fc9-comp-macro.png Rotate
Simulation Rotate function to allow accurate rotation during simulation. Automatically called by any attached coupling or gearbox component.
Fc9-f32-icon.png - FLOAT Angle
Amount to rotate the shaft input in degrees
Fc9-comp-macro.png ReadAbsolutePosition
Reads the absolute angular position of the motor. Returns an integer value representing the step position.
Fc9-conn-icon.png Encoder Resolution
Fc9-type-21-icon.png Output States
Number of unique output states
Fc9-type-15-icon.png Resolution
The resolution of the encoder in degrees
Fc9-type-16-icon.png Number of Pins
Sets the number of output pins on the encoder and hence the resolution of the encoder.
Fc9-type-5-icon.png Pin0
Input pin 0
Fc9-type-5-icon.png Pin1
Input Pin 1
Fc9-type-5-icon.png Pin2
Input Pin 2
Fc9-type-5-icon.png Pin3
Input Pin 3
Fc9-conn-icon.png Simulation
Fc9-type-12-icon.png Poiner Style
Fc9-type-16-icon.png Repeat Rate
Simulated repeat rate when clicking and rotating the encoder
Fc9-type-16-icon.png Style
Fc9-conn-icon.png Custom Colours
Fc9-type-23-icon.png Fill
Fc9-type-2-icon.png Frame Outline
Fc9-type-23-icon.png Frame Fill
Fc9-type-2-icon.png Pointer Outline
Fc9-type-23-icon.png Pointer Fill
Fc9-type-2-icon.png Text
Fc9-type-2-icon.png Tick Mark Outline
Fc9-type-23-icon.png Tick Mark Fill
Fc9-type-2-icon.png Cap Outline
Fc9-type-23-icon.png Cap Fill
Fc9-type-13-icon.png Main Image
Fc9-type-13-icon.png Cap Image
