Component: IoT Made Easy (Comms: IoT/Cloud)
| Category | Comms: IoT/Cloud |
IoT Made Easy component
A component designed to simplify MQTT comms allowing for multiple data streams to be dealt with in a simple manner. Deals with translating values to and from the broker from topic strings into message IDs and numeric values. Works with lots of different MQTT brokers.
FREE
| ErrorAsString | |
| Error | |
| GetTopicID | |
| Compares the topic ID of the last received message with enabled IDs. Returns the topic ID received. | |
| Connect | |
| Connect to the MQTT Server. Returns the connected state. 0 if not connected, 1 if successful connection, or already connected. | |
| GetPayloadInteger | |
| Get the Payload of the last received (Read) packet as a signed long value | |
| LastError | |
| Returns the last error | |
| Read | |
| Read incoming data. Returns non-zero if packet received. Use GetTopicID and GetPayloadXXX to read the contents. | |
| Disconnect | |
| Disconnects from the MQTT server and the network | |
| GetPayloadFloat | |
| Get the Payload of the last received (Read) packet as a floating point value | |
| GetPayloadString | |
| Get the Payload of the last received (Read) packet as a string value | |
| Payload | |
| Size | |
| Starts up the MQTT component - call this after initialising the NetworkComms component. | |
