| Version | 2.0 |
| Category | LEDs |
RGB LED APA102C component
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Allows RGB LEDs to be driven with full 24-bit colour depth. Allows single chains, 2D arrays and 3D cube formations to be simulated. Supports Bit Banged or SPI peripheral based data modes.
BASICIO
|   | SetBrightness |
| Allows the output colour brightness of the LEDs to be scaled down. For example to save current usage or to reduce brightness in dark environments. |
|  - FLOAT | Scaler |
| Range: 0.0 to 1.0 Default: 1.0, 0 = Off, 0.5 = Half Brightness, 1.0 = Full Brightness |
|  - VOID | Return |
|   | GetLEDColour |
| Sets the colour of a single LED in RAM as a 1D array. |
|  - UINT | LED |
| LED to change the colour / Range: 0 to (LED Count - 1) |
|  - BYTE | ColIdx |
| 0 = R, 1 = G, 2 = B |
|  - BYTE | Return |
|   | SetBrightnessByte |
|  - BYTE | Scaler |
| Range: 0 to 255 Default: 255, 0 = Off, 128 = Half Brightness, 255 = Full Brightness |
|  - VOID | Return |
|   | DrawLine2D |
| Draws a line on a 2D array of LEDs |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | SetLEDColour |
|  - UINT | LED |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | SetAllLEDColour |
| Sets the colour of all the LEDs in RAM |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | Refresh |
| Clocks out the current colour data to the LEDs from the values stored in RAM |
|  - VOID | Return |
|   | ShiftLEDs1D |
| Shifts the LED colours in 1D and wraps |
|  - BYTE | Direction |
| 0 = Forwards, 1 = Backwards |
|  - BYTE | DataMode |
| 0=ResetToZero, 1=WrapAroundDisplay, 2=Smear |
|  - VOID | Return |
|   | DrawLine3D |
| Draws a line on a 3D array of LEDs |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | Z1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - UINT | Z2 |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | GetLEDIndex2D |
| Sets the index of a single LED in RAM as a 2D array. |
|  - UINT | X |
| LED Column to change the colour / Range: 0 to (LED Column - 1) |
|  - UINT | Y |
| LED Row to change the colour / Range: 0 to (LED Row - 1) |
|  - UINT | Return |
|   | DrawRectangle2D |
| Draws a basic 2D rectangle onto the LEDs |
|  - BYTE | X1 |
|  - BYTE | Y1 |
|  - BYTE | X2 |
|  - BYTE | Y2 |
|  - BYTE | DrawStyle |
| Sets the draw style - 0=Soild, 1=Edge, 2=Corners |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | ShiftLEDs2D |
| Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable*** |
|  - INT | X |
| Number of pixels to shift the display -1 to 1 / 0 = No Shift |
|  - INT | Y |
|  - BYTE | DataMode |
|  - VOID | Return |
|   | GetLEDIndex3D |
| Gets the index of a single LED in RAM as a 3D array. |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | Z |
| LED Layer to change the colour / Range: 0 to (LED Layer - 1) |
|  - UINT | Return |
|   | DrawCuboid3D |
| Draws a basic 3D cuboid onto the LEDs |
|  - BYTE | X1 |
|  - BYTE | Y1 |
|  - BYTE | Z1 |
|  - BYTE | X2 |
|  - BYTE | Y2 |
|  - BYTE | Z2 |
|  - BYTE | R |
|  - BYTE | G |
|  - BYTE | B |
|  - VOID | Return |
|   | Initialise |
| Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to  initialise all the WS2801 ICs in the chain. |
|  - VOID | Return |
|   | ShiftLEDs3D |
|  - INT | X |
|  - INT | Y |
|  - INT | Z |
|  - BYTE | DataMode |
|  - VOID | Return |
|   | Properties |
|   | LED Arrangement |
| Controls the arrangement of the LEDs on the panel.  1D - Creates a straight line of LEDs 2D - Creates an X by Y Array of LEDs 3D - Creates an X by Y by Z Array of LEDs |
|   | LED Count |
| Total number of LEDs in the design |
|   | LED Columns |
| Number of horizontal LEDs - X axis |
|   | Column Spacing |
| X Spacing Between LEDs on the Panel |
|   | LED Rows |
| Number of vertical LEDs - Y axis |
|   | Row Spacing |
| Y Spacing Between LEDs on the Panel |
|   | LED Layers |
| Number of LED layers - Z axis |
|   | Layer Spacing |
| Z Spacing Between LEDs on the Panel |
|   | Flip X |
| Flips the X axis if the LEDs are wired from the right hand side of the display. |
|   | Flip Y |
| Flips the Y axis if the LEDs are wired from the bottom side of the display. |
|   | Flip Z |
| Flips the Z axis if the LEDs are wired from the upper most side of the display. |
|   | LED Current Usage |
|   | Data Pin |
| LED Data Pin - Connected to the Data In pin of the first WS8201 IC. |
|   | Clock Pin |
| LED Clock Pin - Connected to the Clock In pin of the first WS8201 IC. |
|   | Channel |
| SPI Channel selector |
|   | Prescale |
| Prescale option selector |
|   | MOSI |
| SPI Data Out Pin SDO - Also Known as Master Out Slave In (MOSI) when used in Master mode. |
|   | MISO |
| SPI Data In Pin SDI - Also Known as Master In Slave Out (MISO) when used in Master mode. |
|   | CLK |
| SPI Clock Pin CLK - The Clock signal is driven by the SPI master. |
|   | Connections |
|   | Output Mode |
| Sets the output mode used to drive the data to the LEDs Bit Banged Mode = Allows Any I/O Pin but may be slower SPI Mode = Fixed SPI Peripheral Pins but may be faster - Note that the SPI MISO pin will not be available for general I/O |
|   | Simulations |
|   | Scope Traces |
| Selects if the scope traces are automatically generated or not |
|   | Console Data |
| Selects if the console data is automatically generated or not |
|   | API |
