Component: Airplane Landing Gear (Scenarios)
Revision as of 16:29, 7 January 2022 by Wiki bot (talk | contribs)
Category Scenarios
Airplane Landing Gear component
A simulation of an Airplane Landing Gear containing, switches, locking mechanisms and retracting landing gear.
MODELS
Airplane Landing Gear Scenario
FrontDoors
Will allow the front doors to open.
- BYTE Direction
Drops the door down or close them. 0 = Close 1 = Open
FrontDoorCloseSwitch
Test to see if the Front door will touch the collision switch by its original position. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended
LandingGearDownSwitch
Test to see if the Landing Gear will touch the collision switch by its final position. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended
RearDoorLocks
Will unlock or lock the rear doors
- BYTE OpenOrClose
Open =1 Close =0
LandingGearUpSwitch
Test to see if the Landing Gear will touch the collision switch above it. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended
FrontDoorOpenSwitch
Test to see if the Back door will touch the collision switch by its final position. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended
FrontDoorLocks
Will lock or unlock the front doors depending on the number given to the paremeter.
- BYTE OpenOrClose
Open =1 Close=0
LandingGear
Retracts and drops the landing gear.
- BYTE Direction
Drop the wheel down or retracts them. 0 = Retracts 1 = Drop
RearDoorCloseSwitch
Test to see if the rear door will touch the collision switch by its original position. If it does, will return true. and stop movement.
RearDoors
Will allow the rear door to open
- BYTE Direction
Drop the door down or close them. 0 = Close 1 = Open
RearDoorOpenSwitch
Test to see if the rear door will touch the collision switch by its final position. If it does, will return true. and stop movement.
Simulations
