| Author
Matrix Ltd
| Version
1.6
| Category
EBM Modules
GLCD (EBM001) component
Graphical display component designed to work with the EBM001 modules and EB084 E-blocks. Based on the ILI9163C 16-bit colour graphical controller IC.
FREE
EBM001 Basic Example
EBM001 gLCD Example File
EBM001 Example
EBM001 Maze Builder
Maze Builder gLCD
3D Manipulations
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
BacklightOn
| Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Plot
- UINT
X1
- UINT
Y1
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
FastPlot
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0.
SetDisplayOrientation
- BYTE
Orientation
BacklightOff
| Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BPlot
- UINT
X1
- UINT
Y1
Window
| Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed.
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
- BYTE
Red
| 0 - 255 where 0 = no red and 255 = maximum red
- BYTE
Green
| 0 - 255 where 0 = no green and 255 = maximum green
- BYTE
Blue
| 0 - 255 where 0 = no blue and 255 = maximum blue
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Pixel Width
Pixel Height
Monochrome
Foreground Color
Background Color
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Data
| Data pin connection
Clock
| Clock pin connection
Chip Select
| Chip select pin connection
A0
| Instruction / Command pin connection
Reset
| Reset pin connection
LED
| LED backlight strobe pin connection
Simulations
