| Author
Matrix Ltd
| Version
1.8
| Category
Alphanumeric
LCD (Adafruit, 16x2) component
Adafruit OLED LCD display capable of displaying 2 lines of 16 characters.
DISPLAYS
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
A simple example that shows how to use some common functions.
Adafruit LCD Example
Clear
| Clears the entire contents of the display.
PrintString
| Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro
- STRING
Text
PrintAscii
| Takes the ascii value for a character and prints the character
- BYTE
character
| Holds an ascii value.
| Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT
Number
RAMWrite
| Modifies the internal memory of the LCD to allow for up to 8 customised characters to be created and stored in the device memory
- BYTE
Index
| Values 0 to 7
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
ClearLine
| Clears a single line on the display before moving the cursor back to the start of the line to allow new data to be displayed.
- BYTE
Line
Cursor
| Moves the cursor on the LCD Display
- BYTE
x
- BYTE
y
Command
| Use this method/macro to send a specific command to the LCD. Refer to the Matrix Multimedia EB006 datasheet for a list of supported instructions. For Non-Matrix LCD's refer to the manufacturers datasheet.
- BYTE
instruction
| Send a defined command to the LCD Screen. See datasheet for supported commands.
ScrollDisplay
| Scrolls the display left or right by a number of given positions.
- BYTE
Position
| Holds the number of positions to shift the display
- BYTE
direction
| 0 = left, 1 = right
Start
| Startup routine required by the hardware device. Automatically clears the display when complete.
Rows
| Number of vertical characters that can be shown on the display
Columns
| Number of horizontal characters that can be shown on the display
Background Color
| Simulation only property to control the background colour, on the hardware the colour is fixed.
Line Color
| Simulation only property to control the line colour, on the hardware the colour is fixed.
Text Color
| Simulation only property to control the text colour, on the hardware the colour is fixed.
Font
| Simulation only property to control the display font, on the hardware the font is fixed.
Data 0 (11)
| Data pin 0 connects to data pin 4 on the hardware
Data 1 (12)
| Data pin 1 connects to data pin 5 on the hardware
Data 2 (13)
| Data pin 2 connects to data pin 6 on the hardware
Data 3 (14)
| Data pin 3 connects to data pin 7 on the hardware
Register Select (4)
| Register select pin, determines if the incoming value is a command or a data byte
Read / Write (5)
| Read / Write pin determines the data direction
Enable (6)
| Enable pin, used to clock data in and out of the device.
Simulations
