Component: Switch Array (Slide) (Switches)
| Author | MatrixTSL |
| Category | Switches |
Switch Array (Slide) component
An array of up to eight slide switches. In embedded mode each switch is connected to a single pin of the specified port.
Please click here for the component source code: FC_Comp_Source_Switch_Array_Slide_2dgi.fcfx
Here is an example Flowcode program to read the values of a switch array.
Switch Array
(5V / 11K) * 10K = 4.54545V
| ReadState | |
| Read the state of the switch at the given index. | |
| Index | |
| The switch to read the status of. | |
| WaitUntilHigh | |
| Pause the program until the switch at the given index is turned on. | |
| Index | |
| Index of the switch to wait for. | |
| ReadAll | |
| Reads all of the switches at once, returning a byte containing one bit per switch. | |
| GetHandle | |
| Retrieves the object handle of the switch component at the given index. | |
| Index | |
| WaitUntilLow | |
| Index | |
