Save and Open Projects
Opening a Flowcode Project
There are several ways of opening an existing Flowcode flowchart.
- Select the 'Open' option from the 'File' menu (File > Open), click on the 'Open'
 button from the main toolbar or press Ctrl+O on your keyboard. This will allow you to browse for the file you want. - Select the file from the list of most recently used files at the bottom of the 'File' menu.
 - Double click on a flowchart file in Windows Explorer to launch Flowcode and open the file.
 - Drag a file from Windows Explorer into the Flowcode application when it has no dialogue boxes open to load the file.
Saving a Flowcode Project
To save a flowchart, either select the 'Save' or 'Save As' options from the File Menu (File > Save / Save As), click the 'Save'
 button on the main toolbar or press Ctrl+S on the keyboard. Flowcharts must be saved before they can be compiled to C or transferred to a microcontroller.
Autosave
Flowcode has a built in auto-save feature built into it where it will save your project file periodically to a backup file labelled the same as your current project but with the .fcbx file suffix. You can set how often this autosave feature happens in the Global Options in Flowcode.
