Component: Display Manager (Graphical Library)
| Author | MatrixTSL |
Display Manager component
Please click here for the component source code: FC_Comp_Source_DisplayManager.fcfx
The component can create the follow objects.
Type_line - A simple straight line.
Type_Rectangle - A simple rectangular box.
Type_RectangeFilled - A filled rectangular box.
Type_Ellipse - A simple ellipse or circle.
Type_EllipseFilled - A filled ellipse or circle.
Type_TextBox - A text area allowing a line of text to be displayed.
The type can be entered by using the public constants. Begin with the Display Manager handle name followed by :: and the list of the public variables will be displayed.
For example... DisplayManager1::Type_TextBox
An example showing the creation of some text areas inside formatted shapes.
| MoveObject | |
| Moves an existing object to absolute coordinates on the screen. | |
| ObjectID | |
| X | |
| Y | |
| ShiftObject | |
| Shifts an existing object coordinates on the screen relative to the previous coordinates. | |
| ObjectID | |
| X | |
| Y | |
| DrawObject | |
| Draws a single object onto the display without clearing the display. Doesn't draw a textfield component, this is done using the SetObjectText macro. | |
| ObjectID | |
| ScaleObject | |
| Changes the width and height of the selected Object | |
| ObjectID | |
| Width | |
| Height | |
| RedrawAll | |
| Clears the display and redraws all the content from the display manager objects. Doesn't draw textfield components, this is done using the SetObjectText macro. | |
| CreateObject | |
| Define an object on the graphical LCD. Returns the Object ID. | |
| ObjectType | |
| X | |
| Y | |
| Width | |
| Height | |
