Component: LED Mono (LED)
| Category | LED |
LED Mono component
Please click here for the component source code: FC_Comp_Source_LED_Mono_2dgi.fcfx
Here is an example Flowcode program to read the value of a switch and pass the value on to he LED.
LED Example
| TurnOn | |
| SetState | |
| Sets the state of the LED, accounting for the polarity. | |
| State | |
| 1=On, 0=Off | |
| TurnOff | |
