API Component.Property.GetValue
Jump to navigationJump to search![]() |
GetValue |
Gets the value of a property as a string | |
Handle |
The component handle of the property owner | |
Property |
The textual name of the property | |
Return |
This call gets the value of a property. All properties are stored as strings internally, though this call will allow the value to be returned (and converted) to a variable of any type.
Note it is the expression of the property that is returned. For example, if a property called connection represents port A, reading the value of connection will return the value of port A, where as this call would return the string "$PORTA", which is the stored representation of the property.
In short, referencing the property variable gets the result of the properties expression, while this call gets the expression itself.
- Add to a calculation icon:
result = ::Component.Property.GetValue(handle, "property")
