API FCD.GetItemHandle
Revision as of 15:57, 16 January 2014 by JonnyW (talk | contribs) (XML import)
<sidebar>API Contents</sidebar> Gets a FCD items handle, suitable for traversal with the Tree API
Class hierarchy
FCD
GetItemHandle
HANDLE PathName
An existing handle or the '.' separated path through the FCD to look in
STRING ItemName
The name of an item in the path to find
HANDLE
Returns the FCD items handle, suitable for traversal with the Tree API
This will get a handle suitable for traversal by the Tree API which is a collection of functions suitable for traversing the FCD files.
FCD files are XML files. The PathName must be a list of items, not including the XML root tag of the tags where the XML attribute ItemName is to be located. So to extract a handle to the FLASH memory size Pathname="device.memory" and ItemName="bytes".
If the ItemName is not found in the specified location then a 0 handle is returned.
  • Add to a calculation icon:
    result = ::FCD.GetItemHandle(pathname, "itemname")
