Component: 3D Printer (Scenarios)
Revision as of 17:43, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.4
Category Scenarios
3D Printer component
A simulation only version of a very basic 3D printer such as a standard RepRap.
Please click here for the component source code: FC_Comp_Source_3D_Printer.fcfx
3D Print Using Standard 3D Printer CAD file
A simulated 3D print using an external G code file from an actual 3D printer. The G code file must be placed into the same directory as the Flowcode project to work correctly. G-Code_Parser File:Batman.G
3D Maze Generator
A simple 3D maze generator using the 3D printer component to draw the maze. Maze_Builder_3DP
ClearPrevPrint
Clears all of the content from any previous print cycles.
ControlPrintHead
Controls the print extruder which plots the location of the print head as the head moves. If Enable = 0 then the extruder is disabled If Enable != 0 then the extruder is enabled
- BYTE Enable
Controls if the extruder is active or not
MoveByXYZ
Moves the print head by the amount specified in the axis variables using linear interpolation.
- INT X
- INT Y
- INT Z
SetMovementSpeed
Allows the movement speed to be set progmatically. Range 0 - 100
- BYTE Speed
Speed control (0 - 100)
MoveToHome
Returns the print head to the start position (0,0,0)
MoveToXYZ
Moves the print head to the specific location specified in the axis variables using linear interpolation.
- UINT X
- UINT Y
- UINT Z
MoveByXYZReal
- FLOAT X
- FLOAT Y
- FLOAT Z
SetMovementSpeedReal
Allows the movement speed to be set progmatically. Range 0.0 - 100.0
- FLOAT Speed
MoveToXYZReal
- FLOAT X
- FLOAT Y
- FLOAT Z
Sets up the 3D printer component by homing, clearing old print data and assigning the movement speed.
Bed Colour
Specifies the colour of the print bed.
Print Colour
Specifies the colour of the print output.
Print Speed (0-100)
Specifies the speed of the printer movements. 100 = as fast as possible.
Print Type
Specifies how the print is drawn. Object based - uses panel primitives to build up the 3D object, useful for simulated interaction e.g. the formula flowcode and the maze solving example. Point cloud based - uses the point cloud interface to allow complex objects to be built without slowing down the panel interface.
Print Size
Specifies the size of a single print object.
Print Shape
Specifies the shape of the print object.
Max Print Dimensions
X Width
Printer dimensions X axis
Y Length
Printer dimensions Y axis
Z Height
Printer dimensions Z axis
