Component: LCD (BL0169) (E-blocks 2)
| Version | 1.0 (Release) |
| Category | E-blocks 2 |
LCD component to drive the E-blocks 2 BL0169 LCD board. Provides a 4 x 20 character alphanumeric display.
Make sure each data pin is connected to the right place in flowcode, which corresponds to the port that the LCD board is connected to on your E-blocks 2 upstream board. There are component macros you can use to print things on the LCD screen, in the form of a formatted number, an integer number, a string or the character which corresponds to an inputted ascii value.
You must use the ‘Start’ macro in the program before you can take any data on the LCD.
Clear
PrintString
- <- STRING Text
- Enter the text or variable to print to the LCD
PrintAscii
- BYTE character
- Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
- Enter the number or variable to print to the LCD
RAMWrite
- BYTE Index
- Values 0 to 7
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
ClearLine
- BYTE Line
- The line to clear, zero being the first (top) line of the display
Cursor
- BYTE x
- Set the cursor position in the X plane, 0 is the left most cell
- BYTE y
- Set the cursor position in the Y plane, 0 is the top most cell
Command
- BYTE instruction
- Send a defined command to the LCD Screen. See datasheet for supported commands.
PrintFormattedNumber
Will allow you to print a number up to 32-bits with signed or unsigned formatting.
Signed = -2147483648 to 2147483647
Unsigned = 0 to 4294967295
- ULONG Number
- BOOL Format
- 0=Signed, 1=Unsigned
ScrollDisplay
- BYTE Position
- Holds the number of positions to shift the display
- BYTE Direction
- 0 = left, 1 = right
RawSend
Sends data to the LCD display
- BYTE data
- The data byte to send to the LCD
- BOOL type
- A boolean to indicate command type: true to write data, false to write a command
RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters.
The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE RemapIdx
- Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE SearchCharacter
- Character to look for a replace
- BYTE ReplacementCharacter
- New character value to use in place of the search character.
Start
Startup routine required by the hardware device.
Automatically clears the display after initialising.
Simulation macro reference
Data 0 (11 / 7)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_Data_0.
Data pin 0 - Connects to Data 4 on the hardware in 4-bit mode or Data 0 in 8-bit mode
Data 1 (12 / 8)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_Data_1.
Data pin 1 - Connects to Data 5 on the hardware in 4-bit mode or Data 1 in 8-bit mode
Data 2 (13 / 9)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_Data_2.
Data pin 2 - Connects to Data 6 on the hardware in 4-bit mode or Data 2 in 8-bit mode
Data 3 (14 / 10)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_Data_3.
Data pin 3 - Connects to Data 7 on the hardware in 4-bit mode or Data 3 in 8-bit mode
Register Select (4)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_RS.
Register Select Pin - Informs the display if a command or data is about to be sent.
Enable (6)
This property is of type Single digital pin and can be referenced with the variable name LCD1::Pin_E.
Enable pin - Used to synchronise data writes to the display
