Component: Injector (API Digital Input) (Test Injectors)
Revision as of 17:47, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.2
Category Test Injectors
Injector (API Digital Input) component
Data injector to allow a physical digital input pin to be attached to a simulated component. The component will poll for any input state changes via SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly interface with a physical I/O pin.
Please click here for the component source code: FC_Comp_Source_InjectorSCADADigitalInput.fcfx
Fc9-comp-macro.png InitialiseInjector
Fc9-string-icon.png - STRING InjectorName
Fc9-comp-macro.png RxByteCount
Returns the number of bytes currently sat in the receive buffer.
Fc9-comp-macro.png TxByte
Fc9-u8-icon.png - BYTE DataByte
Fc9-type-17-icon.png API Slave
Fc9-type-16-icon.png Number of Pins
Specifies the number of pins the component can monitor and control.
Fc9-type-16-icon.png Poll Rate
Fc9-conn-icon.png Pin 0
Fc9-type-5-icon.png Simulation I/O Pin
Pin monitored by the simulation
Fc9-type-21-icon.png SCADA Slave Pin
Pin used by the connected SCADA Slave hardware
