Component: LTSR Current Transducer (Electrical)
Revision as of 17:48, 9 November 2022 by Wiki bot (talk | contribs)
Author medelec35
Category Electrical
LTSR Current Transducer component
LTSR rage of +/- 6, 15 & 25A current Tranducers
Please click here for the component source code: FC_Comp_Source_LTSR_Current_Transducer.fcfx
Fc9-comp-macro.png Current
Fc9-type-16-icon.png Device
Fc9-type-15-icon.png VDD
Fc9-type-6-icon.png Channel
