Component: Piezo Sounder (Audio Output)
Version | 1.0 |
Category | Audio Output |
Piezo Sounder component
Drives a simple variable frequency piezo sounder in hardware and simulates the sound in simulation. To actually drive a piezo you may have to amplify the signal from the microcontroller using a transistor or MOSFET.
Please click here for the component source code: FC_Comp_Source_PiezoSounder.fcfx
Here is a simple example that will create a siren effect using a piezo sounder.
Piezo Siren
Depending on your Piezo Sounder you may need to amplify the signal from the microcontroller using a NPN transistor or N channel FET.
BuzzerOnDelay |
Switch the Buzzer on for a fixed amount of time | |
Time |
Time in milliseconds to keep the buzzer on | |
Frequency |
Frequency to output in Hz | |
Return |
Properties |
Output Pin |
Pin used to drive the output to the buzzer |
