API Scope.FindOutput
Revision as of 12:19, 14 May 2013 by JonnyW (talk | contribs) (XML import API changes)
<sidebar>API contents</sidebar> Searches back through the output history for a value, returns offset of found sample from TimeUS, 0 if not found
Class hierarchy
Scope
FindOutput
HANDLE StreamH
The stream that is to be read
LONG TimeUS
The time offset to start the search from, in microseconds
LONG SearchMax
The maximum number of microseconds to look back over, -ve to search backwards
FLOAT Value
The target value to search for
ULONG SearchFlags
Bit 0 is find lower, bit 1 is equal, 2 is find higher
Typical values for this parameter:
Name Description
Find_Lower Match a search when output is lower than the target value
Find_Equal Match a search when output is equal to the target value
Find_Higher Match a search when output is greater than the target value
Find_LowHigh Match a search when output goes lower to higher than the target
Find_HighLow Match a search when output goes higher to lower than the target
LONG Returns offset of found sample from TimeUS, 0 if not found
  • Declare a variable 'result' of type LONG
  • Add to a calculation icon:
    result = ::Scope.FindOutput(streamh, timeus, searchmax, value, ::Scope.Find_Lower)
