Component: Switch Extension ()
Revision as of 17:51, 9 November 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray;" | Categ...")
Author
Category
Switch Extension component
An extension to the default switch Overlays the switch with a mesh
Please click here for the component source code: FC_Comp_Source_Switch_ext.fcfx
Here is an example Flowcode program to read the value of a switch. FC6 Icon.png Switch
(5V / 11K) * 10K = 4.54545V
