Component: UART Software (Timer) (Comms: Interface)
Revision as of 17:52, 9 November 2022 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: Interface
UART Software (Timer) component
Creates a reliable software UART that can be driven using a timer interrupt setup by the user. The timer interrupt must be interrupting at the required baud rate. e.g 9600Hz.
Please click here for the component source code: FC_Comp_Source_UART_Software_Timer.fcfx
Simple example showing how to enable a timer interrupt at the desired baud rate then receive a string. If anything is received then it will be echoed back out and displayed on a LCD
FC6 Icon.png UART_Timer_Example
Fc9-comp-macro.png SendString
Sends an string to the transmit buffer
Fc9-comp-macro.png ReceiveArray
Gets an array of values from the receive buffer. Returns number of values received.
Fc9-u16-icon.png - UINT Values
Fc9-u16-icon.png - UINT NumValues
Fc9-u16-icon.png - UINT Timeout
Time in milliseconds to wait for data
Fc9-comp-macro.png SendArray
Sends an array of values to the transmit buffer
Fc9-comp-macro.png UART_Timer_Process
Called as part of a timer interrupt at the specific UART baud rate.
Fc9-comp-macro.png ReceiveValue
Gets a single value from the receive buffer
Fc9-comp-macro.png SendValue
Sends a single value to the transmit buffer
Fc9-comp-macro.png CheckBuffer
Returns the number of values in the transmit or receive buffer
Fc9-bool-icon.png - BOOL Buffer
0=Transmit / 1=Receive
Fc9-comp-macro.png ReceiveString
Gets a string from the receive buffer
Fc9-u16-icon.png - UINT MaxChars
Fc9-comp-macro.png Initialise
Initialises the UART component pins ready to send and receive data
Fc9-conn-icon.png Global Settings
Fc9-type-16-icon.png Data Bits
Fc9-type-16-icon.png Stop Bits
Fc9-type-7-icon.png Use TX
Allows the Transmit pin to be enabled / disabled
Fc9-type-7-icon.png Use RX
Allows the Receive pin to be enabled / disabled
Fc9-conn-icon.png Transmit Properties
Fc9-type-5-icon.png Transmit Pin
Pin assigned to transmitting data
Fc9-type-21-icon.png Transmit Buffer Size
Number of bytes that can be stored in the outgoing transmit buffer
Fc9-conn-icon.png Receive Properties
Fc9-type-5-icon.png Receive Pin
Pin assigned to receiving data
Fc9-type-21-icon.png Receive Buffer Size
Number of bytes that can be stored in the incoming receive buffer
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
